Explain/solve the Matching Problem in the simplest terms
  • Thread starter Thread starter redphoton
    Terms
The "Matching Problem" often refers to scenarios where items from one set must be matched with items from another, such as the classic example of an absent-minded secretary randomly stuffing letters into envelopes. The probability of a match occurring can be calculated by determining the probability that a match does not happen, denoted as P, and then using the formula 1-P for the probability of a match. This problem can be explored through various mathematical approaches, including graph theory and combinatorics. Understanding these concepts helps clarify the complexities of matching in different contexts. The discussion emphasizes the importance of probability in solving matching problems.
redphoton
Explain/solve the "Matching Problem" in the simplest terms
How would you explain and solve the "Matching Problem" to a HS math club? give the simplest explanation and solution you know.
You mean the stable matching problem, from graph theory?
matching problem like the classic: "An absent-minded secretary prepares n letters and envelopes to send to n different people, but then randomly stuffs the letters into the envelopes. A match occurs if a letter is inserted in the proper envelope. Find the probability a match happens."
There are many different problems involving matching one set against another.
If P is the probability that a match DOESN'T happen, then 1-P is the probability that a match happens. Is this what you want?
The standard _A " operator" maps a Null Hypothesis Ho into a decision set { Do not reject:=1 and reject :=0}. In this sense ( HA)_A , makes no sense. Since H0, HA aren't exhaustive, can we find an alternative operator, _A' , so that ( H_A)_A' makes sense? Isn't Pearson Neyman related to this? Hope I'm making sense. Edit: I was motivated by a superficial similarity of the idea with double transposition of matrices M, with ## (M^{T})^{T}=M##, and just wanted to see if it made sense to talk...
  • · Replies 53 ·
  • · Replies 0 ·
  • · Replies 18 ·
  • · Replies 29 ·
  • · Replies 40 ·
