How Does Time Dilation Affect Clock Readings in Different Frames?
Time dilation affects clock readings between different frames, particularly when considering a spaceship traveling from planet A to planet B. While the clocks on planets A and B are synchronized and read L/v when the spaceship arrives, the spaceship's clock reads L/γv due to time dilation effects. The key issue arises from the non-simultaneity of clock resets between the spaceship and the planets, which leads to the apparent paradox of differing time readings. The resolution lies in recognizing that events considered simultaneous in one frame may not be simultaneous in another, specifically for the spaceship. Understanding this non-simultaneity is crucial for reconciling the different clock readings observed.
bigevil
Two planets A and B are at rest with respect to each other and are L apart in this frame. They have synchronised clocks. A spaceship flies at speed v with respect to planet A and synchronises its clock with A-B.
We know that when the spaceship reaches B, B's clock reads L/v and the ship's clock reads L/γv. How would someone account for the fact that B's clock reads L/v, which is more than its own L/γv, considering that the spaceship sees B's clock as running slow.
I'm not sure if I got the correct solution, please help me to check if the reasoning is correct.
Let the frame A-B measure (x,y,z,t).
Let the ship measure coordinates (x',y',z',t').
Using the Lorentz transformation for time,
t' = \gamma (t - vL/c^2)
When A-B resets its clock at zero (t=0), t' registers - vL\gamma / c^2. Relative to the time of A-B, the ship's clock runs at vLγ/(c*c) slower.
When the ship passes B, time at AB is t = L/v. Then,
\gamma (\frac{L}{v} - \frac{Lv}{c^2}) = \frac{L}{\gamma v}.
My solution:
When I reset my clock at A, this event is not simultaneous with the time reset at the two planets. In fact, the planets have a "head start" of vLγ/c^2. In the planet's time it takes L/v for me to reach there. In my time, to adjust for the head start, the time to reach B is L/γv.
The resolution of the paradox (that my clock is slower on my ship than the planet's, although due to time dilation, I should read the planet's clock as slower) lies in the assumption that the time reset of the A-B system and the reset of the ship are simultaneous, but they are not.
Hi bigevil! :smile:
this is all very confusing :redface:
what's all this about "resetting"? :confused:
i can't see whether you've got it or not …
the important question is whether times on A and B which are simultaneous for A (or B) are also simultaneous for the spaceship :wink:
  • · Replies 67 ·
