Explanation of Iodine Equilibrium in immiscible solvents
The discussion focuses on the equilibrium of iodine (I2) in two immiscible solvents: varsol and aqueous potassium iodide (KI). Participants explore the molecular behavior of iodine in these solvents, the color changes associated with different iodine species, and the effects of varying concentrations on iodine distribution between the two layers.
  • Homework-related
  • One participant describes the expected behavior of iodine in varsol and aqueous KI, noting that I2 is non-polar and prefers varsol, while KI leads to the formation of I3- ions in the aqueous layer.
  • In Scenario 1, the participant hypothesizes that adding a saturated solution of I2/KI will not change the observed colors of the layers, as iodine will redistribute until equilibrium is reached.
  • In Scenario 2, the participant suggests that adding saturated KI will make the pink layer lighter and the yellow layer more intense due to increased I3- formation.
  • Another participant corrects a minor detail regarding the form of iodine in varsol, affirming the understanding of the problem.
  • A follow-up question is raised about how changes in reagent concentrations affect iodine distribution, specifically whether increasing I3- would lead to a greater yellow color in the aqueous layer or shift the equilibrium to produce more I2 and I- in the varsol layer.
  • A later reply confirms that both processes will affect the partition of iodine between the phases, referencing the concept of partition coefficients.
Participants generally agree on the behavior of iodine in the two solvents, but there is ongoing exploration regarding the effects of concentration changes on the equilibrium and distribution of iodine species. No consensus is reached on the specific outcomes of the follow-up question.
The discussion includes assumptions about the behavior of iodine in different solvents and the implications of concentration changes on equilibrium, which remain unresolved. The exact nature of the interactions and the mathematical treatment of the equilibrium are not fully detailed.
kirsten_2009
I'm studying the equilibrium of I2 and its distribution in two immiscible liquids (varsol and aqueous potassium iodide). Since I2 is non polar; it will "prefer" to be in varsol but since KI (aq) is an ionic salt solution, iodine will also dissolve to give the I3- ion. When iodine is present in varsol = pink color and when in KI = yellow.
I think I understand what happens but I'm a little confused as to what would be observed in the following situations, any clarification would be really appreciated.
Scenario 1: 2 mL iodine/potassium iodide (aq) + 2 mL of varsol..."shake"...then add saturated solution of I2/KI ...what would be observed? What is happening on a molecular level?
Scenario 2: 2 mL iodine/potassium iodide (aq) + 2 mL of varsol..."shake"...then add saturated KI...same questions.
I2 (aq) + I- <---> I3- (aq)
I2 (aq) <---> I2 (varsol)
So this is my understanding of the situation, please correct me if I'm wrong. Iodine will be present in both organic and aqueous layer because its soluble in both. When Iodine is in varsol it's in the form of I- ions = pink color. When iodine is present in the aqueous KI solution its in the form of I3- ions = yellow color. So initial solutions should appear with pink varsol layer on top and yellow aqueous layer at bottom.
Scenario 1: When saturated solution of I2/KI is added I would think that nothing (no change) is observed and that the layers continue to be pink on top and yellow at bottom because more iodine is being added but also more KI so the iodine will just redistribute itself in the two layers until it's reached equilibrium. Iodine can just have more I3- since it has more solvent now to do so in (equilibrium would shift right).
Scenario 2: When saturated KI solution is added I would think that the pink layer would become lighter and the yellow layer more yellow since there is more KI for iodine to dissolve in and so more I3- ions would be formed (equilibrium would shift right).
kirsten_2009 said:
Iodine is in varsol it's in the form of I- ions I2 molecules = pink color.
Other than that little correction (you've got it that way elsewhere) I'd say you've understood the problem.
Great, thank-you! And as a follow up to all this and as a conclusion...in the I2 (aq) + I- (aq) <----> I3- (aq) equation if any of the reagent's concentration was changed...this would affect the iodine distribution between the two liquids, correct? But, let's say I3- was increased would that mean that the aqueous layer would be greater or more yellow because there are more I3- in the aqueous layer or would it means that because I3- was increased the reaction would shift to the left and more I2 and I- would be formed in the varsol layer thus making the varsol layer greater and more pink?
kirsten_2009 said:
would that mean
kirsten_2009 said:
or would it
"Yes." Both processes are going to affect the "partition" of iodine between the phases, hence, the study of "partition coefficients."
22K
  • · Replies 21 ·
13K
