Express (p ∨ q) using only ∧ and ¬ operators
5 replies · 2K views · last reply
johnsmiths
find a logical expression using only ∧ and ¬ operators which is logically equivalent to (p ∨ q)
losing direction
what should I first consider?
There is another question about recurrent relation.
Suppose that a mathematical expression can only be formed by the following symbols: 0, 1,
2, …, 9, ×, +, /. Some examples are “0 + 9”; “2 + 2 × 8”; “1 / 5 + 6”. Let an be the the number
of such mathematical expression of length n (e.g. “0 + 9” is considered of length 3). Find a
recurrence relation for an and compute the closed form for an.
[Some clarification: We define a number as follows
- 0, 1, 2, …, 9 is a number
- If x is a number, then x0, x1, …, x9 is a number
We define a valid expression as follows
- E is a valid expression if E is a number
- If E, F are valid expressions, then E + F, E × F, E / F are also valid expressions.
For example: 1+50/4 is an expression of length 6, and 09×00/5 is an expression of length 7.]
Totally no idea about this question.
losing direction
You should consider what it means to be logically equivalent, then look up "tautologies."
What do you mean is finding something [tex]\rightarrow[/tex] ( p[tex]\vee[/tex]q ) and make it a tautology?
johnsmiths said:
What do you mean is finding something [tex]\rightarrow[/tex] ( p[tex]\vee[/tex]q )?
I do not understand what the above question is asking.
Do you understand what it means when two statements are logically equivalent?
It means p[tex]\leftrightarrow[/tex]q is a tautology.
Maybe I make some mistakes with my question. And after I know that, what should I do next?
Just guessing or there is a systematic way to work out the solution.
It's not guessing, but it's not really "systematic" because it's a very simple question. All you need to do is use what you know about tautologies to construct an equivalent statement. The original statement p v q has a very simple logical equivalent that you should be able to deduce with only a little thinking once you find the proper tautological statement.
