Extra energy needed to thrust perpendicular to orbital plane
5 replies · 2K views · last reply
Albertgauss
Does anyone know where I can find information about how to calculate how much extra energy is required of a spaceship to try to thrust perpendicular (or at some angle) to the orbital plane verses flying completely/only in the orbital plane when moving outwards in our solar system? If the spaceship does thrust perpendicular to the orbital solar system plane, will the sun's gravity try to bring the ship back into the orbital plane?
Astronomy news on Phys.org
No, gravity is symmetrical in all directions. The only reason that it would be easier to travel along the orbital plane is because your launch point is also traveling along that plane so you already have some momentum. It's the same reason that all launches happen as close to the equator as possible and always go in the same direction that the Earth is rotating.
Once in orbit, you should not require any fuel no matter how you are oriented in regards to the solar system.
The planets are all in a plane because they formed from a spinning blob of dust that formed the sun 4.6 billion years ago. The self-interaction of that gas cloud and spinning motion of it formed it into a disk. Much further out, objects orbit in all lots of different obits. The Oort cloud is theoretically spherical.
Oh, I see. Just a check on my logic: Thus, if there was a satellite or comet orbiting at an oblique angle with respect to the orbital plane for some reason and no space gas, the satellite or comet should then stay in that orbit. Is this correct?
For all practical purposes: yes. Once in orbit, it will stay there. There are some known comets that have orbits like that.
If it's in the solar system, the gravity of Jupiter (and the rest of the planets to a less degree) will pull anything towards the plane of the planets, but it'd have to be out there for millions of years to be noticeable.
If by "orbital plane" you mean the Sun's equatorial plane, Then you should be made aware of the fact that none of the planets actually orbit exactly in that plane. Mercury orbits closest to this plane. The ecliptic, or the Earth's orbital plane, is tilted by some 7.25 degree to the Sun's equatorial plane. Relative to the ecliptic the other planets have inclinations that vary from 0.77 to 3.39 degrees (Pluto's orbit is at 17.15 degrees to the ecliptic.) The main body of the asteroid belt includes objects with as much as 30 degree inclinations.
Okay, I got it. Thanks for your help everyone. I'm good to go now.
