Factor 2e^3x - 5xe^3x and 4lnx - 3ylnx
  • Thread starter Thread starter name_ask17
    Check my work Work
2 replies · 3K views · last reply
name_ask17
Okay, I think these are simple, but just so I know that I am on the right track, can you double check my work? My questions and answers are in bold.
Factor these completely:
1. 2e^3x - 5xe^3x
2. 4lnx -3ylnx
3. The Attempt at a Solution
1. I took out the e^3x to make the factored problem e^3x(2-5x)Did I do that right, because I get confused when dealing with the exponents. If there is more to it, can you explain please? Thanks in advance.
2. I just took out the lnx to make it lnx(4-3y) . Is this correct?
1. 2e^3x - 5xe^3x
2. 4lnx -3ylnx
They are both correct but you need parentheses. For example e^(3x). Also, while not incorrect, it is better to write the last one (4-3y)ln(x) to remove any possible misunderstanding about what is inside the ln function.
Thanks! Just wanted to make sure they were correct because it seemed too simple. Guess I'm used to overthinking things. lol.
