Factoring Trigonometric Expression.
6 replies · 2K views
anemone
MHB
POTW Director
Decompose the expression below into real factors:
$$1-\sin^5 x-\cos^5 x$$
Mathematics news on Phys.org
A possible procedure is to use the identities...
$\displaystyle \sin x = \frac{2\ t}{1+ t^{2}}$ $\displaystyle \cos x = \frac{1-t^{2}}{1+ t^{2}}$ (1)... where $\displaystyle t = \tan \frac{x}{2}$. In this case we obtain... $\displaystyle 1 -\sin^{5} x - \cos^{5} x = \frac{(1+t^{2})^{5} - (1 - t^{2})^{5} - 32\ t^{5}}{(1+t^{2})^{5}} = \frac{2\ t^{2}\ (t-1)^{2}\ (t^{6} + 2\ t^{5} + 3\ t^{4} + 4\ t^{3} + 15\ t^{2} + 10\ t + 5)}{(1+t^{2})^{5}}$ (2)
The problem now is, of course, to pass from the factorization in t to the factorization in x...Kind regards $\chi$ $\sigma$
I think it's easy to deduce that $1 - \sin x$ is a factor. If we re-write our expression as
$1 - \sin^5 x - \cos^3x(1-\sin^2 x) = $$(1 - \sin x)(1 + \sin x + \sin^2 x + \sin^3 x + \sin^4 x) - \cos^3 x(1 - \sin x)(1 + \sin x)$
Similarly for $1 - \cos x$ by $1 - \cos^5x - \sin^3 x(1 - \cos^2 x)$ but have not been able to get both of them out. The graph suggests that both are there as there are only two zeros on $[0,2\pi]$. One at $x = 0$ and the other at $x=\pi/2$.
If we write $z = e^{ix}$, the expression becomes
$$1−\left(\frac 1 {2i}(z-z^{-1})\right)^5−\left(\frac 1 2(z+z^{-1})\right)^5$$
According to Wolfram, this is equal to
$$\frac{(\frac 1{32}+\frac i{32}) (z-1)^2 (z-i)^2 (1+(2-2 i) z-9 i z^2-(12+12 i) z^3-9 z^4-(2-2 i) z^5+i z^6)}{z^5}$$
As an observation, if we set it to zero, we find the roots $z=1$ and $z=i$ (each of multiplicity 2) that translate to $x=0 \pmod{2\pi}$ and $x=\frac \pi 2 \pmod{2\pi}$.
We can rewrite the expression as
$$\frac 1{32}(1+i) (z^{\frac 1 2}-z^{-\frac 1 2})^2 (z^{\frac 1 2}-iz^{-\frac 1 2})^2 (z^{-3}+(2-2 i) z^{-2}-9 i z^{-1}-12(1+i) -9 z-(2-2 i) z^2+i z^3)$$
$$\frac 1{32}(1+i) (z^{\frac 1 2}-z^{-\frac 1 2})^2 (z^{\frac 1 2}-iz^{-\frac 1 2})^2 (i (z^3 - iz^{-3})-2(1-i)(z^2 - z^{-2})-9 (z+i z^{-1})-12(1+i))$$
We can verify that
$$\left\{ \begin{aligned}
z+z^{-1}&=2\cos x \\
z-z^{-1}&=2i\sin x \\
z-i z^{-1}&=(1-i)(\cos x - \sin x) \\
z+iz^{-1}&=(1+i)(\cos x + \sin x)
\end{aligned}\right.$$
So we can further simplify it, which I will do in a later post...
Either way, the important factors for the roots are $(\sin \frac x 2)$ and $(\cos \frac x 2 - \sin \frac x 2)$.
OK, I got the other term. Here's what I have so far.
$(\sin x -1)(\cos x -1)(3 + 3 \sin x + 3 \cos x + 2 \sin x \cos x - \sin^3 x-\cos^3 x)$.
Next is to show that the 3rd term is always positive.
OK, I think I got the rest of this. The third term can be written as
$\dfrac{1}{2}\left(\sin x + \cos x + \dfrac{2}{3}\right)^3 + \dfrac{5}{6}\left(\sin x +\cos x + \dfrac{2}{3}\right) + \dfrac{35}{27}$.
So this term is cubic in the variable $\sin x + \cos x + \dfrac{2}{3}$ which is increasing so is minimum would be at the left endpoint of the interval of interest. Now the trig terms can be written as
$\sin x + \cos x + \dfrac{2}{3} = \sqrt{2} \sin \left( x + \dfrac{\pi}{4}\right) + \dfrac{2}{3}$
from which we can deduce that the interval of interest is
$\left[\dfrac{2}{3} - \sqrt{2}, \dfrac{2}{3} + \sqrt{2}\right]$Substituting the left endpoint into the cubic shows it is positive, thus giving that
$3 + 3 \sin x + 3 \cos x + 2 \sin x \cos x - \sin^3 x - \cos^3 x > 0$
We can verify that
Thanks to both of you for showing that the factorization could also be done by using those two different useful trigonometric substitutions. I want to thank to both of you too for taking the time to participating to this challenge problem.
And I like Serena, I am looking forward to see your next post because I know what you are going to post will benefit the readers for sure.:)
This is exactly what I did to get the first two real factors and
I am impressed with how easy the desired result you obtained (i.e. to prove the third factor is always positive for all real $$x$$) by setting up the third factor in terms of $$\sin x+\cos x+\frac{2}{3}$$.
Thanks for the posts and insights, Jester!:)
P.S. The way that I proved the third factor is always positive for all real $$x$$ is by the graphing method.:o
