Falling Dumbbell: Determine Force vs Angle
  • Thread starter Thread starter sergiokapone
    Falling
30 replies · 5K views
sergiokapone
Determine force vs angle, that acts on the vertical wall from the falling dumbbell. Dumbbell falls without initial velocity. The mass of each bead of dumbbell is m.
The problem need to be solved using only Newton's equations by writing them for each of the material points.
I do not know how I find the acceleration of the points.
hi sergiokapone! :wink:
start by drawing two free-body diagrams, one for each ball
(call the positions of the two balls x and y, and find how x'' and y'' depend on θ and on each other)
show us what you get :smile:
What wall? Is there a diagram missing?
wot? no wall? :biggrin:
x=lcosα
y=lsinα
l - the length of the conjunction
x2+y2=l2
good morning! :smile:
sergiokapone said:
x=lcosα
y=lsinα
x2+y2=l2
(ahh, it's that way round!)
ok, that's the full diagram
now draw the two free-body diagrams, one for each ball, marking the forces clearly on each
I solved the problem. But in addition to Newton's laws, I had to use the law of conservation of energy.
In the projections on the direction along the dumbbell:
mgsinα-R=mv2/l
R - reaction from the rod.
x=lcosα
y=lsinα
Differentiating, we find velocity
v=l dα/dt
The law of conservation of energy: mgl=ml2dα/dt2/2+mglsinα
Using Newton's third law, force, that acts on the vertical wall F=Rcosα
or, finally
F=mg(3sinα-2)cosα
How can you do without the law of conservation of energy?
sergiokapone said:
x=lcosα
y=lsinα
x2+y2=l2
So far so good. What about the forces on the falling end?
Love it! Would he be Chad, Kilroy or Foo to you?
See my previous post, please, where I have already written, it is the reaction force from the connecting rod and the force of gravity.
divide the reaction at the wall into Rx and Ry, and call the interaction between the two balls T
do ∑F = 0 for the wall ball, and ∑F = ma for the other ball
he was (i understand) prolific in and after the second world war here in britain, announcing shortages, but i don't think he usually had a name, or was known by one (though apparently technically he was mr chad) :wink:
OK
1st ball:
Rx=Tcosα
Ry=Tsinα
2nd (falling) ball:
Tcosα=max
Tsinα-mg=may
sergiokapone said:
Tcosα=max
Tsinα-mg=may
ok, now write ax and ay in terms of α (or write cosα and sinα in terms of x and y), and solve :wink:
cosα = x/l
sinα = y/l
Concerning what to solve?
I do not understand.
Moreover, a(α) depend on second derivative of α, which is unknown.
ax=-..α lsinα-l.α2cosα
(.. - second time deriv, . - first time deriv )
might be easier to do it the other way …
mx'' = Tcosα = Tx/l which is a lot easier to solve :wink:
(write ' and '' for deriviatives)
x=aexp(sqrt T/ml t)
oh, hold on, T isn't constant, so you'll have to eliminate T first, before trying to integrate …
that should give you the same equation you'd get if you treated it as a single rigid-body and took moments of forces about the corner
I went back to the problem.
For the center of mass of the dumbell I have:
## 2m \vec a_{cm} = 2m\vec g + \vec R## (1)
##a_{\tau}=gcos\alpha##
##v_{cm}=-\frac{d\alpha}{dt}l##
##l## - halflength of the dumbell.
##\frac{dv_{cm}}{dt}=gcos\alpha##
or
##v_{cm}{dv_{cm}}=-gcos\alpha d\alpha##
Integrating, I find:
##a_{n}=2g(1-sin\alpha)##
Substituting in equation (1) of ##a_{n}##
##2ma_{n}=2mgsin\alpha-R##
Finally
##R=2mg(3sin\alpha-2)##
Is the factor ##2## near ##mg## is correct?
or
Finally
I'm not sure what all your unknowns represent, so I can't follow your logic. The lower mass doesn't play any role, so you can ignore it. It has no horizontal acceleration, and since no radius is given for it you have to ignore any KE for it.
I don't get the factor of 2.
But what about the law of motion cernter of mass? In this law we need use total mass of the dumbell. Looks like paradox.
You don't have to treat the dumbbell as a single object. You can treat each end mass and the bar joining them as separate objects.
Then I need to include a unknown force from the joinig bar in equation for the falling mass.
##m\frac{d\vec v}{dt} = m\vec g + \vec F_{bar\,reaction}##
And I basically want to understand how to apply the equation of motion of the center of mass. Therefore I want
to consider dumbell as a single object .
Ok, but as I said you need to define all your variables. If ##a_\tau## is the tangential acceleration of the mass centre, how do you calculate that it equals ##g\cos(\alpha)##?
haruspex said:
Ok, but as I said you need to define all your variables. If a_\tau is the tangential acceleration of the mass centre, how do you calculate that it equals ##gcos(α)g\cos\alpha## ?
May be, it was my mistake. I think the correct answer is:
##a_{\tau_{CM}}=g/2 \cos\alpha##
Using the law of motion of the center of mass: ##2m\vec a_{CM}=2m\vec g + \vec R## in projection to the tangential direction (##\vec R## - acts along the bar)
##2ma_{\tau_{CM}}=2mg \cos\alpha##
I get ##a_{\tau_{CM}}=g \cos\alpha##
I think, this is my primary mistake.
In that equation, R is the total reaction from the ground. This is not the same as the force along the bar. The difference is the weight of the lower mass.
