Faraday's disk and "absolute" magnetic fields
128 replies · 16K views · last reply
Buckethead said:
The wire is perpendicular to the field and the circle scribed by the wiggle is in the plane that is also perpendicular to the field
I haven't worked it out in detail, but I think there will be no EMF induced on such a wire from the static field. I.e. This is a physically different scenario from when the wire is wiggled in the homogenous region of the coil.
Buckethead said:
We are looking at a relative situation here, moving the wire relative to the coil or moving the coil relative to the wire.
It is not relative. Accelerometers attached to the wires or the coils will be different in the two different situations. These two situations are not symmetric, they are two physically different scenarios.
A Faraday disk (even one that allows rotation of the magnet, the disk, and the return circuit independently) alone cannot demonstrate whether or not the magnetic field rotates with the magnet or is stationary or is somethi ng for which rotatio is not an apt descriptor.
A Faraday dish (with indipendently rotating components) shows that the requirement for current is relative rotation between the disk and the remainder of the circuit.
Perhaps with a setup where the return ircuit is significantly shielded and a magnetic flux return path is built away from the return circuit more certainty woukd be available.
This is a really good point and one that slipped by me entirely. If the wire is moving at a constant velocity linearly or the coil is doing so instead then I believe the situation is symmetric, but circular motion introduces acceleration and I can see how that would be different. I suppose it follows that even linear acceleration of the coil or wire is not symmetric. Is this true?
The Faraday disk is a clumsy setup when trying to analyze the relationship between the disk and the field but this relationship is put to rest in an experiment done in the early 20th century (sorry I don't have a name for this or a reference). The setup consists of 2 concentric metal cylinders with a small gap between them and a single wire connecting the two cylinders located halfway down their length. A round magnet is located at one end of the cylinders around the axis of the cylinders.
The cylinders are rotated and the magnet is either held stationary or rotated relative to the cylinders (doesn't matter). After a while, remove the wire and stop the rotation and measure the voltage between the two cylinders (which is essentially a capacitor). In both cases there is a voltage. You can now discharge the cylinders and just rotate the magnet and no charge will show. This indicates the rotation of the cylinder relative to the field and not the magnet is what is causing the voltage.
Yes, I agree.
I think that is correct also. If you were to write Maxwell's equations in an accelerating reference frame then they would look different than the usual form.
I may have missed it but: You can represent the EM field (in this case a magnet) as a 4by4 antisymmetric matrix, a good representation of a tensor. This tensor is cast into other reference frames by multiplying the tensor with a lorentz matrix/tensor. Both the rows and columns have to be transformed so multiplication has to be on both sides when viewing the situation as a matrix. Now the electrons have their own reference frame that determines the Lorentz force they feel.
Just because the magnetic field isn't changing in magnitude; it doesn't imply it isn't changing. The changing can always be interpreted as the generated electric field. Orthogonal to the pointwise magnetic field and relative velocity vectors.
If the electron were rotating with the field it shouldn't experience a Lorentz force.
Unfortunately, I don't recall if there are second order effects due to the acceleration the electron would be undergoing. One is certain Cherenkov radiation.
I pretty sure the above is a good representation of the mathematics/physics but am open to constructive criticism; I have done any research on this for ages.
I'm not clear on the setup you are describing.
Are the cylinders locked to rotate together? If this is the case, I am surprised this is occurring without relative motion between the two.
...or are the cylinders rotating with respect one another? If that is the case, it is difficult to understand how you can distinguish between the net of relative motion between each of the cylinders and the magnet as opposed to relative motion just between the cylinders.
I really need to have a reference for this experiment!
I really need to have a reference for this! I did have the Faraday disk in mind at one point and the cylinders seem to contradict what I remember (not hard but I would like explicit details).
So, when a disk-shaped magnet spins, no electric field is detected. Why is that?
Let's say the disk is magnetic because there are microscopic current loops all over the disk. When the disk is spinning, we can say a microscopic current loop is approximately in linear motion. Now we know that a moving current loop is an electric dipole, there was a discussion about that some time ago here.
So, what kind of macroscopic electric field is caused by those microscopic dipoles? Well the rim of the disk becomes charged. Every point of such disk has the same potential. So there are no currents in static wires that are brushing the disk.
TSny said:
There is no meaning to absolute rotation of the disk. As Paul Colby points out in post #20, the return path must also be considered.
Here is a video that shows various cases of parts of the setup moving relative to other parts.
The video link in your post is quite helpful. Relative motion of the disk and stator are clearly shown to be important. I think I converged to the wrong answer to the question I posed in post #47.
Read my FAQ article! It's just using a spherical magnet, because then everything can be calculated in terms relatively simple standard functions. The short message is: When a magnet spins in general you have an electric field, and that's where the voltage measured in the homopolar-generator setup comes from. It teaches us once more that electrodynamics is a relativistic phenomenon, and thinking in non-relativistic terms can be misleading. All socalled paradoxes are gone, as soon as you use fully relativistic reasoning, among other things the apparent Faraday-disk paradox, the phenomenon of socalled "hidden momentum", which is not hidden but just an incomplete balance equation when using the electromagnetic momentum and at the same the non-relativistic approximation for mechanical momentum of the moving charges etc. etc.
Here's the link to the FAQ article again:
http://th.physik.uni-frankfurt.de/~hees/pf-faq/homopolar.pdf
vanhees71 said:
... When a magnet spins in general you have an electric field, and that's where the voltage measured in the homopolar-generator setup comes from. It teaches us once more that electrodynamics is a relativistic phenomenon, and thinking in non-relativistic terms can be misleading. All socalled paradoxes are gone, as soon as you use fully relativistic reasoning, among other things the apparent Faraday-disk paradox...
A 'belief' in the absolute superiority of one particular model is also a path that can mislead. Regardless of how elegant and complete a model (relativity in this case) might seem, when the predictions don't align with empirical data, then the implementation or the model is misleading
The data show spinning the magnet has no effect on voltage in a faraday disc. Only the relative movement of the two parts of the circuit (disc and return path).
"Essentially, all models are wrong. Some are useful" - George E. P. Box.
"The data show spinning the magnet has no effect on voltage in a faraday disc"
Can I have a reference for the experiment?
Reference https://www.physicsforums.com/threa...te-magnetic-fields.918885/page-4#post-5798780
References abound. Reply #46 details in table form the results of the various combinations of revolving or stationary for the magnet, disk and return circuit. These results occur every time. Note that spinning the magnet or holding it stationary has no effect and that current is only produced for conditions with relative motion between the disc and return circuit.
Uhh, except that relativity does align with the data. That should be clear since Maxwell's equations are relativistic.
Well, I understood some of that.
My idea was that there is a disk-shaped magnet, and there is a charge floating nearby the magnet. If the magnet moves linearly, the charge feels a Lorentz-force. When the magnet spins, the charge feels different Loretz-forces from different parts of the magnet, as the different parts move almost linearly to different directions. The sum of those Lorentz-forces is zero.
Hm, but as with my example of the rotating spherical magnet, also a rotating disk-shaped magnet should result in an electric field, and thus there should be a force on the charge near the magnet.
Concerning the other discussed setup with the rotating cylinder, I guess it's more demonstrating the Hall effect, i.e., conduction-charge separation when the cylinders are rotating due to the Lorentz force. If you rotate the magnet instead, the electric field may be way too weak to have a measurable effect on the charges of the cylinders.
The idea that relativity is disproven by Faraday's findings is absurd, because to the contrary only with relativity you can correctly describe these effects, and the Maxwell equations are the paradigmatic example for a relativistic field theory. That's why relativity was discovered by analyzing the Maxwell equations.
Relativity does provide a useful model, however if your interpretation predicts a meaningful effect on current produced the spinning of the magnet (in the classic Faraday disc set-up); your implementation is doing a disservice to relativity.
Please take notice of the bias favoring theory over impiricism in the short response you did leave. Your argument is nonsequitur. The fact that Maxwells equations are relativistic has exactly squat to do with alignment with a real set of data.
Agreed. However, your rotating magnet example has no return path for a current. Topologically it's not a circuit so any electric field will move charge till there is no field because the magnet is also conducting. If I understand correctly, it's only when the stator-return-path part rotates relative to the conducting disk part that there is a current. The "reason" for the current in the relatively rotating parts is the flux enclosed by the circuit is changing and the charge is free to flow around a closed circuit. If the stator-return-path part is stationary with respect to the conducting disk path there is no net flux change and no current flow.
I don't see anyone claiming relativity is disproven. I would say that if you predict that spinning just the magnet in a classic Faraday disc set up will lead to current, then your implementation of relativity is flawed.
Also, your claim that 'only with relativity can you correctly describe there effects is unsupportable. Moreover it mistakes a modep of reality for the fundamental causes.
You are correct I did not explicitly make the complete argument, but I thought the rest of the argument would be understood by anyone with a basic understanding of the homopolar motor, Maxwell's equations, and relativity.
Maxwell's equations correctly predict the empirically observed behavior of the homopolar motor, Maxwell's equations are relativistic, therefore relativity also does "align with the data" for the homopolar motor.
No, I just calculated the electric field. To measure the corresponding voltages you should use a volt meter with high resistance. I guess, it's not a good generator in the sense that you can get high currents from it.
It's also very difficult to discuss only very vaguely defined setups. Is there somewhere a clear description of the experiments with rotating cylinders discussed? I have a vague idea what it might be about, and if so, it's very easy to understand that this is a rotating conductor in an external magnetic field. Then you have of course charge separation due to the Lorentz force on the electrons building up a counteracting electric field, leading to a charge of the cylindrical capacitor, which you can measure with help of a volt meter after taking away the connecting wire. This is very similar to the DC Hall effect, where the only difference is that in the usually discussed version of the Hall effect the current is a conduction current due to a voltage applied to the conductor, while here it is a convection current due to the rotation of the cylinder. The physics is the same: Maxwell's equations + the law of the Lorentz force ##\vec{F}=q (\vec{E}+\vec{v}/c \times \vec{B})##, both together forming a set of equations that are of course fully compatible with relativity (but not with Galilei symmetry).
Another question is what happens, if you rotate the magnet. Since, if I'm guessing the setup right, the magnet is just under the cylinders, when rotating the electric field induced along the cylinder is very weak, so that its effect may be well negligible. Of course, without a clear description of the experiment, it's impossible to say anything concrete. One thing, however, I'm pretty sure about is that it won't contradict relativity and the Maxwell equations. Of so, we'd all know this sensation very well ;-)).
More so for the homopolar motor/generator you even need relativity to explain it right!
Can you please give a concrete setup of your experiment? What I completely disagree with is the claim that the Faraday disk experiment of any kind contradicts relativity. If so, it would be a sensational finding leading with a very high probability to a trip to Stockholm in December ;-).
Taking the setup in
https://en.wikipedia.org/wiki/Homopolar_generator#Disk-type_generator
you an pretty easily describe what's going on. Let's make the simplifying assumption that the magnetic field ##\vec{B}=\text{const}## along the disk. Then in the stationary state
$$\vec{j}=\sigma (\vec{E}+\vec{v}/c \times \vec{B})=0.$$
We have ##\vec{B}=(0,0,B)## and ##\vec{\omega}=(0,0,\omega)## and thus ##\vec{v}=\vec{\omega} \times \vec{r}## and thus
$$\vec{E}=-\frac{\vec{v}}{c} \times \vec{B} = -\frac{\omega B}{c} (\vec{e}_z \times \vec{r}) \times \vec{e}_z.$$
Now we have
$$(\vec{e}_z \times \vec{r}) \times \vec{e}_z =\vec{r}-z \vec{e}_z =(x,y,0).$$
Thus we have (inside the disk)
$$\vec{E} = -\frac{\omega B}{c} (x,y,0)=-\frac{\omega B}{2c} \vec{\nabla} (x^2+y^2).$$
Thus the electric potential is
$$\phi=\frac{\omega B}{2c} (x^2+y^2).$$
The voltage measured from the center to the rim of the disk thus is
$$U=\frac{\omega B R^2}{2c},$$
where ##R## is the radius of the cylinder.
All this is completely relativistic (particularly I used the complete relativistic version of Ohm's Law in the very beginning!).
Like I continue to reitterate, yes relativity does provide robust predictions of reality. However if your interpretwtion of relativity has you predicting the rotation of the magnet alone meaningfully affects current in a classic faraday disk setup, then you are misapplying relativity.
Please point out the person claiming relativity has been contradicted. ..all I see are people claiming someone has state relativity has been contradicted.
You plainly contradict my calculation about the rotating magnetic, which is based on relativity. The homopolar generator, however, works. You find it in many good textbook on electrodynamics (e.g., Becker+Sauter, Sommerfeld vol. III).
Ok I admit that there is a force on a charge near a spinning magnet.
So the Lorentz-forces from all the microscopic magnets do not cancel out, like I said before. I only said the forces cancel out because I though there should be no force on the charge.
That is substantially different from
The "or the model" part in particular is objectionable.
The model (relativity in this case) is consistent with all of the current and historical empirical data within its domain of applicability. People do make mistakes, but those are strictly "implementation" mistakes rather than "implementation or the model".
The cylinders are always rotating together. Regardles if the magnet rotates or not, if the cylinders spin, there is a charge buildup. This is a beautiful example to show it is the relationship between the spinning object and the magnetic field and not between any two rotating objects that is key in the Faraday disk.
