Faraday's disk and "absolute" magnetic fields
128 replies · 14K views
Dale said:
Yes, I agree.
I think that is correct also. If you were to write Maxwell's equations in an accelerating reference frame then they would look different than the usual form.
So something isn't working out here. If a wire accelerating and within the Helmholtz field is not symmetrical to a Helmholtz coil being accelerated with a non-accelerating wire in the field then this means if you do one or the other you will get two different voltages right? This would imply that if a wire stationary to the coil were to be mounted in a ship and if the ship were to accelerate then there would be a voltage generated. This couldn't be the case or due to the equivalence principle, such a stationary setup in a gravitational field would also generate a voltage.
What would be wrong with that?
The two gravitational equivalents would be a wire at rest on a planet with the coil free falling around it ( equivalent to case of inertial coil in SR), and coil at rest on planet with wire falling through (equivalent to accelerating coil case in SR). I would indeed expect these equivalent cases to behave identically if they are not too large (the principle of equivalence is a local principle).
So a wire accelerating though an inertial coil, or a coil accelerating past an inertial wire generate the same voltage? It was mentioned in post 61 that the two situations are not symmetrical, but now I see what was meant was only the asymmetry between the two objects but this does not affect the outcome. Either one accelerating will generate the same voltage.
If this is the case, then this gets me back to an earlier post where moving a wire in a circle (without rotating it) in a magnetic field is the same as rotating the coil in the same plane and leaving the wire stationary. In both cases a voltage will be generated in the wire. So again, this must mean that moving the coil in a circle (accelerating it) must also move the field lines such that they are forced to cut across the wire. So again, it seems you can move a single field line in a circle, but you cannot rotate the field lines about themselves (which would happen if you rotated the magnet instead of the disk).
I find this peculiar.
I think you misunderstood me. A wire accelerating through an inertial coil is POE equivalent to a wire resting on Earth as a free fall coil passes. In no way did I claim the equivalence you suggest. Please reread my prior post more carefully. Please note that a free fall coil is not accelerating per GR.
You said "( equivalent to case of inertial coil in SR)" i.e. an inertial coil with a wire accelerating through it at 1G and "(equivalent to accelerating coil case in SR)" i.e. an inertial wire with a coil accelerating around it at 1G. What did I misunderstand?
Oh I get it, you meant the wire at rest on Earth and the accelerating wire in space, were equivalent, not the two experiments.
OK back to sorting this out. So if an accelerating wire through an inertial coil does not generate the same voltage as an accelerating coil around an inertial wire, then it is back to my statement that a wire inside a coil and stationary to it, mounted on an accelerating ship would generate a voltage and thus would also generate a voltage sitting on the Earth. This clearly does not happen, so what is going on?
This looks like a totally separate case. Coaccelerating wire and coil, equivalent to wire and coil resting in earth. It is different from other cases discussed in the past several posts.
Not so different. But first, in the case of the objects resting on Earth, there is no voltage which means accelerating the coil or accelerating the wire must be equivalent. So far so good? This means that moving a wire in a circle or moving the coil in a circle (both acceleration) would also generate the equivalent voltages. This means the field lines when moving the coil must also be moving in a circle.
No, the resting on Earth case suggests NOTHING other than linearly coaccelerating wire and coil will produce no current as measured by a coaccelerating detector.
Post 61 didn't mention anything about this scenario. Post 61 was about the circular "wiggling" acceleration.
No. In post 61 the coil wiggling will not immediately generate voltage while the wire wiggling will. No wiggling acceleration is equivalent to linear acceleration or uniform gravity. Please do not blindly copy-and-paste answers like this.
No! This is highly frustrating. Please go back and re read the earlier comments. Gravity is not equivalent to wiggling something in a circle! Do not confound the two. Nothing we discuss here alters the previous answer.
Yes, this is the correct application of the equivalence principle.
It is not at all clear to me that this does not happen. Have you actually worked it out?
Are you sure? What are Maxwell's equations in gravity, and have you solved them for this case? I haven't, so I would not be surprised to learn there is a voltage, but perhaps you have more experience with Maxwell's equations in gravity than I do
This is completely inequivalent. It is frankly starting to irritate me. Go back to everything that was previously said. I am uninterested in repeating it again.
Dale said:
That is substantially different fromThe "or the model" part in particular is objectionable.
The model (relativity in this case) is consistent with all of the current and historical empirical data within its domain of applicability. People do make mistakes, but those are strictly "implementation" mistakes rather than "implementation or the model".
"Particularly ojectionable": that is bordering on dogmatism. I was merely pointing out the possibilities. While I doubt relativity is inconsistent with the outcome of these experiments, it should never be beyond question. That is a basic tenet of sound science.
What is far more likely is that your interpretation of relativity has gotten off track somewhere. Are you not claiming that a spinning magnet will induce a current in a set up like the faraday disk without relatove motion between the conducting disk and the remainder of the circuit? If you are, that is inconsistent with observation.
If that is not your assertion and if you insist that you are only making a claim about a spherical conducting magnet being spun, realize that your emphasis on the spinning of the magnet is wrongheaded. It is the conductive disk or sphere spinning in relation to the remainder of the circuit in a magnetic field that developes current. There is no spinning field. That is the beauty of separating the magnet from the conductor from the remainder of the circuit.
Instead of whining, you should finally give a concise description of the experiments which make you doubt in the very foundation of physics which is among the best tested fundamental models ever, i.e., (special) relativity. My example of a spherical conducting magnet has been chosen, because you can solve the problem analytically with simple functions. It's not in principle different from any other shape of the magnet. Of course the details of the em. field depend on the shape of the spinning magnet, but it's not qualitatively different.
This isn't how sound science works. In science an extraordinary claim requires extraordinary evidence. Nothing is beyond question, but all claims require evidence. Any claim seeking to overturn more than a century of data without any evidence is "particularly objectionable" and scientifically unsound.
I know that, I have been telling that to the OP from the beginning.
What we have here is a failure to communicate. I don't have any reason to doubt general or special relativity. What I was saying was that if an interpretation of a theory doesn't fit observation then either the theory or application thereof must be flawed...with the implication that it must be the application.
It did seem pretty clear that you were stating that the spinning magnet was motivating the voltage/current. If I misunderstood that or replied to the wrong comment, then I made a mistake.
If you are not saying the spinning magnet motivates the current/voltage, then I am not disagreeing with you,
Where? I certainly did not intend that, but perhaps I wrote something particularly poorly.
Hi. There is a famous "paradox" about a charged particle at rest in magnetic field. No force is working on the particle but In another Lorentz coordinate the particle is moving by v thus Lorentz force vXB works. The answer is in new Lorentz coordinate electric field appears and cancels Lorentz force.
This is a case of translation not rotation, but we can apply this result in parts of rotating magnet where the part is moving ##v=r\omega## and get similar results.
I still don't know the exact setup you are discussing. That's why it's not clear what's going on here. In general, a rotating conducting magnet also implies an electric field as demonstrated in my notes on the homopolar generator:
http://th.physik.uni-frankfurt.de/~hees/pf-faq/homopolar.pdf
To discuss why for some setup you don't measure this electric field, one needs to know the precise setup!
The electric field comes from plus and minus charged parts of the moving coil. Velocities of free electrons in the coil are ##V+v## or ##V-v## or so according to positions in the coil where v is velocity of free electron and V is velocity of Lorenz transformation.
Current is constant in the circuit so slower velocity part contains more electrons so is charged minus and faster velocity part contains fewer electrons so is charged plus.
Applying the case of translation to small circuits that consist permanent magnet, it seems
[tex]\mathbf{P}=-(\omega \times \mathbf{r})\times \mathbf{M}[/tex]
Revolving magnet is dielectric whose polarization is proportional to revolving radius at least in first order approximation of v/c.
Electric field outside revolving thus polarized magnet is order of (v/c)^2. As of first order approximation of v/c, electromagnetic field by revolving magnet, that was called "rotating magnetic field" by OP, is not different from (electro)magnetic field by magnet at rest. Re: post #46 and its improvement #60. For more precise consideration of (v/c)^2 or higher, we should go deeper into theory of both special and general relativity.
Okay, I think a simple experiment can establish that relative motion between parts of the circuit is a necessary part to generate current and that rotation of the conductor around an axis parallel with magnetic field lines will not generate a current if there is not relatove motion between the rotating conductor and the return path, even if the return path could be corotating (no relative motion) AND avoid cancelling the potential developed in the other portion of the circuit, what I am calling the conductor.
Please bare with my explanation of the setup:
Start from a typical Faraday disk setup:
a conductive disk free to rotate about the axis of revolution;
with sliding electrical contacts one around the circumference of the disk and another on an area on and around the center;
concentric and offset below is a circular magnet just larger than the conductive disk which in this case is solidly attached to the conductive disk so as to spin with it.
If a return circuit is provided between the inner and outer sliding contacts and the disk (with accompanying magnet) is rotated sliding in the contacts, we are in agreement current flows in the circuit.
I believe I will still have general agreement if instead of the complete disc, we use just a pie slice on the disk, we will still get a current (albeit reduced) in the circuit as the inner and outer portions of the rotating pie slice of the conductor (with a matching pie slice magnet carried below) slide on the inner and outer contacts.
Taking a second similar pie slice of conductor and magnet, but this time with the polarity flipped along the axis of rotation, if we swap it out between the sliding contacts for the first pie piece and spin it the same direction, the current is reversed.
The return part of the circuit connecting the inner sliding contact to the outer sliding contact can be removed if we complete the circuit by using the original pie piece and the reversed pole pie piece at the the same time, attached to rotate together on opposite sides of the circular path but electically isolated except for the sliding contacts at the center and outer edge.
As long as the sliding contacts are not in isolated segments (as might be use for commutation), but instead provide a low resistance path between the center of the original pie piece to the center of the pole reversed pie piece and also between the outer edge of the two pie pieces, the combination should function as a dc motor or generator.
If anyone believes this will not operate as a motor if current is made to flow through, or as a generator with a prime mover, please let me know why.
If we are okay up to that point, then I can show why rotation of the conductors in the field alone is insufficient to develop current. ... the explanation is undeniably simple and doesn't require even the most cursory dip into relativity.
If the contacts at center as well as the contacts at the outer edge are altered so that instead of sliding, the connections are fixed and rotate the the two connected pie pieces, then the assembly could not function as a homopolar motor. If a battery were mounted and current were driven from the center out the rim of one pie piece, along the circumference then back in the pie piece with the opposite polarity magnet, no torque could be developed without breaking conservation of (angular) momentum, as there is nothing off which it might produce countertorque.
...and if you can't get any rotation by passing current through the nonsliding embodiment, then no current will be produced by rotating the nonsliding embodiment.
Relative motion between parts of the circuit appears more and more as a sine qua non. Rotation (parallel to field lines) of a conductor in a magnetic field does appear insufficient without relative motion in the circuit.
I came across this which demonstrates the capacitor experiment I mentioned earlier. Both videos are well done and worth watching.
Okay, I understand.
Now if somebody could show me the mathematical derivation in terms of Maxwell's equations and/or the electromagnetic two-form, I would appreciate it. It would save me some trouble and thinking. Preferably with very few words.
The mathematical derivation of what?
The voltage measured with different experimental setups?
I'm struggling with this one. It seems the ##v\times B## gives the correct answer. The problem is what is ##v##? In the video ##v## is the velocity relative to the lab frame and ##B## is the field in the lab frame. What I only partially get is that spinning the magnet doesn't change the magnetic field or induce an electric field in the lab (this is what I think is shown by the experiment). The one case not done is spinning magnet+disk+stator. My guess is this would produce no EMF which I find, well, confusing.
