Fiberglass degradation by salt water
The discussion centers around the degradation of fiberglass materials in marine environments, particularly focusing on the effects of salt water and UV exposure. Participants explore the necessity of washing fiberglass boats and the implications of water absorption and oxidation on the longevity of the material.
  • One participant questions the necessity of washing fiberglass boats, seeking to understand whether the degradation is primarily due to the plastic matrix or the glass fibers.
  • Another participant explains that common resins in fiberglass are hydroscopic, which leads to water absorption and necessitates coatings for protection against UV degradation and aesthetic concerns.
  • A follow-up inquiry suggests that UV degradation affects the plastic coating, raising the question of whether washing is effective against such degradation.
  • Concerns are raised about salt absorption along with water, suggesting that salt deposits could form within the fiberglass, potentially causing issues over time.
  • One participant notes that while oxidation is a persistent issue, applying an oxidation-resistant coating would require repeated applications to maintain effectiveness.
Participants express differing views on the effectiveness of washing fiberglass boats and the specific mechanisms of degradation, indicating that multiple competing perspectives remain unresolved.
There are limitations regarding the assumptions about the types of coatings and their resistance to oxidation, as well as the specific chemical interactions between salt water and fiberglass materials that are not fully explored.
This discussion may be of interest to boat owners, materials scientists, and those involved in marine maintenance or fiberglass manufacturing.
Charles123
People always wash their fiberglass boats, the part above water obviously. I was thinking if there is really a need for it? What is suitable to degradation, the plastic matrix, or the fibers of glass? And how does salt water promotes that degradation?
Thank you
Regards
Chemistry news on Phys.org
Fiberglass with common resins is hydroscopic so it absorbs water, hence the reason for coatings. They are washing and waxing the coating to make it look nice. If they did not do that, then the sun and air would degrade it and make it look ugly. But you can recover an ugly coating with a fine abrasive to remove the layer of oxidation.
You have similar but different concerns below the water line. They do that maintenance and repair once every year or two when they haul the boat out of the water and put new bottom paint on it.
Thank you for your answer.
I should think that the effect of the sun is due to UV degradation of the plastic coating. Am I right? If so washing doesn`t help, isn't this the case?
As for the layer of oxidation, what oxides is the plastic coating, is that it? Wouldn’t it be possible to use some coating resistant to oxidation?
Regards
There might be more than just UV degradation of the polymers at work here. If the water is getting absorbed, then the salt is certainly coming along for the ride. There could be concerns about salt buildups forming within the material that could be problematic. Washing with (presumably) fresh water could dissolve and flush out these salt deposits before they get to be an issue.
I don't know enough about this topic to say much else, except that oxidation is an ongoing battle. If you were to apply an oxidation-resistant coating one year, you'd almost inevitably have to do it again at some point afterwards. And again. And again.
  • · Replies 19 ·
9K
