Undergrad How Does Zero Characteristic Influence the Structure of Prime Subfields?
Every field of zero characteristic has a prime subfield isomorphic to ℚ. The proof involves defining a homomorphism h: ℚ → P, where h(a/b) = (a*1)(b*1)-1, with a*1 representing the sum of 1 added a times. The multiplicative rule for this homomorphism has been established, while the additive rule requires further proof. The notation (a*1)(b*1)-1 signifies the inverse of the product of the sums representing integers a and b in the prime field.
  • Understanding of field theory and characteristics of fields
  • Familiarity with homomorphisms in algebra
  • Knowledge of additive and multiplicative structures in fields
  • Basic concepts of commutative algebra
  • Study the properties of fields with zero characteristic
  • Learn about homomorphisms and their applications in field theory
  • Investigate the structure of prime fields and their isomorphisms
  • Explore the additive and multiplicative rules in algebraic structures
Mathematicians, algebraists, and students studying field theory, particularly those interested in the properties of prime subfields and homomorphisms.
Danijel
I am interested in the following theorem:
Every field of zero characteristics has a prime subfield isomorphic to ℚ.
I am following the usual proof, where we identify every p∈ℚ as a/b , a∈ℤ,beℕ, and define h:ℚ→P as h(a/b)=(a*1)(b*1)-1 (where a*1=1+1+1... a times) I have worked out the multiplicative rule for this homomorphism, but I am not sure how to prove the additive. I am also interested in what does the notation
(a*1)(b*1)-1 exactly mean. Thanks.
All we know about the prime field is its characteristic and ##0,1 \in \mathbb{P}##. ##a\in \mathbb{P}## is not sure. However ##\underbrace{1+\ldots +1}_{a \text{ times}}=a \,\cdot \, 1## for ##a \in \mathbb{N}## is, and likewise for negative ##a##. That's why ##a## times ##1## is used instead of ##a##. We only have isomorphic images of ##a## in ##\mathbb{P}##.
For the homomorphism, I guess ##\dfrac{a}{b}+\dfrac{c}{d}=\dfrac{ad+bc}{bd}## will be needed.
this probably won't help much until you have some commutative algebra but it gives the outline. First of all since the field F is an abelian group, there is exactly one additive homomorphism from the integers Z into F for each choice of the image of 1 from Z, so choose that image to be the unit element 1 in P. Now you have the unique additive homomorphism from Z to P that fresh described sending each positive integer n to 1+...+1 (n times). By definition of the multiplication in Z this is also a multiplicative map hence a ring map. Then since each non zero integer goes to an invertible element of F, (because F has characteristic zero), there is a unique extension of the previously defined ring homomorphism Z-->F to a ring homomorphism Q --> F. Then since Q is a field, this ring map is necessarily injective, hence defines an isomorphism onto the smallest subfield of F, i.e. the prime field.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 31 ·
  • · Replies 21 ·
