Find a basis of U, the subspace of P3
In summary, the student is trying to find a basis for U, the subspace of P3, which is the set of polynomials p(x) such that p(7) = 0 and p(5) = 0. The zero polynomial is in this space, but there may not be a third degree polynomial with four zeroes.
Nope
100
U = {p(x) in P3 | p(7) = 0, p(5) = 0}
ax3+bx2+cx+d
p(7)=343a+49b+7c+d=0
p(5)=125a+25b+5c+d=0
d=-343a-49b-7c
d=-125a-25b-5c
ax3+bx2+cx+{(d+d)/2} -->{(d+d)/2}=2d/2=d
(-343a-49b-7c-125a-25b-5c)/2=-234a-37b-6c
ax3+b2+cx-234a-37b-6c
a(x3-234)+b(x2-37)+c(x-6)
basis{x3-234,x2-37,x-6}
dim=3
please check if I m correct or not
and is there a easier way to do it?
also, if
U = {p(x) in P3 | p(7) = 0, p(5) = 0,p(3) = 0,p(1) = 0}
p(x) does not exist?
thanks!
ax3+bx2+cx+d
d=-343a-49b-7c
d=-125a-25b-5c
dim=3
also, if
thanks!
No, that's not right.
Your subspace of P3 is the set of 3rd degree polynomials p(x) such that p(7) = 0 and p(5) = 0. That means that any polynomials in this space must have factors of (x -7) and (x - 5). So any polynomial in this subspace must satisfy (x - 7)(x - 5)(ex + f) = 0, with e and f being arbitrary.
There's more to do, but this will get you going in the right direction.
so the basis would be {(x - 7)(x - 5)x,(x - 7)(x - 5)}? dim=2
please answer this one
does p(x) exist?
it has 4 degree(x - 7)(x - 5)(x - 3)(x - 1), but P3 is a set of third degree, so it does not exist
is that right?
For the first question: yes.
For the second question: there is no 3rd degree polynomial with four zeroes.
can i write does not exist?
thanks!
Sure. "There is no ..." and "does not exist" mean the same thing.
Correction (and thanks to vela!): There is no 3rd degree polynomial with exactly four zeroes, but p(x) = 0x3 + 0x2 + 0x + 0 satisfies p(7) = p(5) = p(3) = p(1) = 0.
does that mean the basis exist {1,x,x2,x3}?
Let's get your questions straight.
1) If U is as described in post #1, what is a basis for U? (Already answered)
2) Is there a polynomial in P3 such that p(7) = p(5) = p(3) = p(1) = 0? Yes, the zero polynomial.
Yes.
But the question in my assignment is
d) U = {p(x) in P3 | p(7) = 0, p(5) = 0,p(3) = 0,p(1) = 0}
and I wrote no basis
If you give the reason, your answer will probably be OK.
1. What is a subspace in mathematics?
A subspace is a subset of a vector space that satisfies all the properties of a vector space. In other words, it is a smaller space within a larger space that follows the rules of vector addition and scalar multiplication.
2. What is a basis in linear algebra?
A basis is a set of linearly independent vectors that span a vector space. It is used to represent any vector in the space as a linear combination of the basis vectors. In other words, it is a set of building blocks that can be used to construct any vector in the space.
3. How do you find a basis of a subspace?
To find a basis of a subspace, you need to find a set of linearly independent vectors that span the subspace. This can be done by finding the null space of the subspace's matrix representation or by using the Gram-Schmidt process to orthogonalize a set of vectors in the subspace.
4. What is the difference between a spanning set and a basis?
A spanning set is a set of vectors that can be used to represent any vector in a space, while a basis is a specific type of spanning set that is also linearly independent. In other words, a basis is the smallest possible spanning set for a vector space.
5. Can you have more than one basis for a subspace?
Yes, a subspace can have infinitely many bases. This is because there are multiple ways to choose a set of linearly independent vectors that span the subspace. However, any basis for a subspace will have the same number of vectors, known as the dimension of the subspace.
  • Precalculus Mathematics Homework Help
  • Linear and Abstract Algebra
