Find a function f that has a continuous derivative
20 replies · 7K views
rjs123
Find a function f that has a continuous derivative on (0, ∞) and that has both of the following properties:
i. The graph of f goes through the point (1, 1)
ii. The length L of the curve from (1, 1) to any point (x, f(x)) is given by the formula L = lnx + f(x) - 1
Recall that the arc length from (a, f(a)) to (b, f(b)) is given by the formula
I think the fundamental theorem of calculus will be useful here... since you know the arc length, you can set it equal to the integral.
micromass said:
So, what did you try already??
I'm not really sure where to start...but I'm assuming I pick a random integer from 1 to infinity to represent b. Since I'm given the equation for f(x)'s arclength from 1 to any point to infinity: L = lnx + f(x) - 1
...should i set it equal to the equation for finding arclength in general? I've never seen this type of problem before so I'm a little puzzled.
Well, you can do what Char limit proposed. The length from 1 to x is given by ln(x)+f(x)-1. But on the other hand, the lenth is also given by
[tex]\int_1^x{\sqrt{1+(f^\prime(x))^2}dx}[/tex]
So, setting them equal gives you
[tex]ln(x)+f(x)-1=\int_1^x{\sqrt{1+(f^\prime(x))^2}dx}[/tex]
Now derive both sides...
Let x = 3
[tex]ln(3)+f(3)-1=\int_1^3{\sqrt{1+(f^\prime(x))^2}dx}[/tex]
[tex]ln(3)+f(3)-1=\int_1^3{{1+(f^\prime(x))}dx}[/tex]
[tex]ln(3)+f(3)-1={{x+(f(x))}} from 3 to 1[/tex]
This is what I have so far...am i on the right path?
rjs123 said:
Let x = 3
I really don't know what you did there. You can't eliminate the square root like that. It is NOT true that [tex]\sqrt{a+b}=\sqrt{a}+\sqrt{b}[/tex]!
Instead, you have to take the derivative of both sides and apply the fundamental theorem of calculus...
dont you mean integral of both sides, and i thought the left side should be left alone...no? I'm stuck on integrating the right side...any help would be appreciated.
becomes this correct?
[tex]1/x+f^\prime(x)={\sqrt{1+(f^\prime(x))^2}[/tex]
Yes, good. Now square both sides and solve for f'(x). Then integrate.
next steps:
[tex](1/x+f^\prime(x))^2={1+(f^\prime(x))^2}[/tex]
[tex]1/x^2+f^\prime(x)^2={1+f^\prime(x)^2}[/tex]
I haven't had calc in a while...if solving for f'(x) wouldn't they cancel each other out here?
You squared the left side wrong.
[tex](a+b)^2 \neq a^2 + b^2[/tex]
[tex](a+b)^2 = a^2 + 2 a b + b^2[/tex]
next steps:
[tex]1/x^2+ 2f'(x)/x + f'(x)^2=1+(f^\prime(x))^2[/tex]
[tex]1/x^2+ 2f'(x)/x=1[/tex]
simple mistake...im now here
multiply by x?
Multiplying by x will help, yes. Then you need to subtract 1/x.
[tex](a+b)^2 = a^2 + 2 a b + b^2[/tex][/QUOTE]
next steps:
[tex]2f'(x) = 1 - 1/x[/tex]
[tex]f'(x) = (1 - 1/x)/2[/tex]
whats a good simplification of the right side for easier integration...[tex]f'(x) = 1/2 - 2/x[/tex]?
f(x) = 1/2x - 2lnx + C ...final answer? i'll double check this right now
There is a mistake here. After multiplying both sides by x, you should get 2f'(x) = x - 1/x. After that, I would treat them separately.
f'(x) = x/2 - 2/x
After integrating
f(x) = 1/4x^2 - 2lnx + C
is there a way to give you reputation or something for your help...i appreciate it.
I don't know if there's a way to do that, and it's not really necessary. Just thanks are good.
Although you should have integrated 1/(2x), not 2/x...
f(x) = 1/4x^2 - 1/2ln(2x) + C
is the C necessary here?
it appears
does not intersect f(x)...im guessing to set f(x) to 1...then find C...by plugging in 1 for x?
1 = 1/4(1)^2 - 1/2ln(2) + C
1 = 1/4 - 1/2ln(2)
3/4 + 1/2ln(2) = C
f(x) = 1/4x^2 - 1/2ln(2x) + 3/4 + 1/2ln(2)
