Find Upper Bound for abs(f(4)(x)) of f(x)=sin(sin(x))
  • Thread starter Thread starter ZuzooVn
    Bound Upper bound
To find the upper bound for the absolute value of the fourth derivative of f(x) = sin(sin(x)), a graphical approach is suggested, starting with plotting y = sin(x) and then x = sin(y). The discussion highlights the complexity of calculating higher derivatives, with one participant noting that the fourth derivative involves a sum of terms with binomial coefficients multiplied by sine and cosine functions, which have maximum values of 1. Wolfram Alpha estimates the upper bound to be around 3.76, while another participant suggests a least upper bound of 8. Clarification on the meaning of f(4)(x) as the fourth derivative is also emphasized in the conversation.
ZuzooVn
help me, please
if f(X) = sin(sin(x)), use a graph to find a upper bound for abs(f(4)(x))
Thanks
Welcome to PF!
Hi ZuzooVn! Welcome to PF! :smile:
ok … draw y = sin(x).
Now turn the paper sideways and draw x = sin(y) …
what do you get? :wink:
Would u please tell me more detail about your solution?
Nope! o:)
Just do it! :smile:
tiny-tim said:
Nope! o:)
Just do it! :smile:
Please
Because, i didn't know how to find the upper bound
tiny-tim has suggested a first step. Have you done it yet?
yes, i have done it .
But because I'm a Vietnamese, so my English skill isn't good :D
Excellent! Thank you.
Now, tiny-tim, what in the world are you talking about? I'm afraid I dont' see your point either.
I would probably use "brute strength"
If y= sin(sin(x)), then y'= -cos(sin(x))(-cos(x))= cos(x)cos(cos(x)). Now, instead of actually doing the other derivatives (because they get really messy!), use the fact that the nth derivative of (f(x)g(x)) will be \sum _nC_i f^{i}g^{n-i} to see that we will, after three more derivatives, have a sum of 4 terms with binomial coeficients times sin and cos- and the largest possible value for sine or cosine is 1.
Unless I made a silly mistake typing things in, it appears that Wolfram Alpha thinks it should be around 3.76.
ZuzooVn said:
help me, please
Thanks
You need to define what f(4)(x) means. Do you mean, the fourth iteration of f on x, i.e. f o f o f o f (x)? Or do you mean (as others have interpreted) the fourth derivative of f?
I means the fourth derivative of f
Do you mean least upper bound? I get 8 as an upper bound.
  • · Replies 0 ·
  • · Replies 56 ·
