Find all 2x2 matrices such that A=A^-1
  • Thread starter Thread starter autodidude
    Matrices
5 replies · 12K views
autodidude
Find all 2x2 matrices such that [tex]A=A^-^1[/tex] (the inverse, just in case the notation is different)
[tex] <br /> A=<br /> \begin{bmatrix}<br /> a & b<br /> \\ c & d<br /> \end{bmatrix}[/tex]
This is my second attempt at this question. The first time, I took a different approach, using the four equations below. This time, I started off with four other different equations and had a very tough time trying to figure it all out. If I hadn't looked at the solutions, I never would've gotten anywhere. Even with it, I struggled a lot and it took an unreasonable amount of time to work it all out...
If [tex]A=A^-1[/tex], then [tex]A^2=I[/tex]. From that, I derived the following equations:
(i)[tex]a^2+bc=1[/tex]
(ii)[tex]ab+bd=0[/tex]
(iii)[tex]ac+cd=0[/tex]
(iv)[tex]d^2+bc=1[/tex]
From (ii) and (iii), if a≠-d, then b=0 and c=0. Then from (i) and (iv),a^2=1 and d^2=1and since a≠-d, then a=1 and d=1 or a=-1 and d=-1
So from that, I get two 2x2 matrices
\begin{bmatrix}
1 & 0
\\ 0&1
\end{bmatrix}
\begin{bmatrix}
-1 & 0
\\ 0&-1
\end{bmatrix}
[/tex]Then to get the others, I let b=0 and c be any real number (again, I never would've done this if I hadn't seen the answers), then to satisfy (iii), a and d would have to be opposite. I did that for c=0 as well and the result was four more matrices
[tex] \begin{bmatrix}<br /> 1 & 0<br /> \\ k &-1<br /> \end{bmatrix}<br /> <br /> \begin{bmatrix}<br /> -1 & 0<br /> \\ k &1<br /> \end{bmatrix}<br /> <br /> \begin{bmatrix}<br /> 1 & k<br /> \\ 0 & -1<br /> \end{bmatrix}<br /> <br /> \begin{bmatrix}<br /> -1 & k<br /> \\ 0&1<br /> \end{bmatrix}[/tex]
To get the last answer given in the book:
[tex] <br /> \begin{bmatrix}<br /> a & b<br /> \\ \frac{1-a^2}b&-a<br /> \end{bmatrix}[/tex]
I just rearranged (i) to get b. But couldn't you write represent c in a similar way but with b in the denominator? Are they just writing it in terms of a and b?
Anyway, though it's solved, it took me super long and I'm still not happy with the method I used. I went down another road where I said b=0 iff a+d≠0 because I used
[tex]b=\frac{-b}{ad-bc}[/tex]
[tex]ab+bd=0[/tex]
[tex]b(a+d)=0[/tex]
[tex]b=0[/tex]
And I also said that if b≠0, then ad-bc-1 and I had all these equations but couldn't get anywhere with them.
Basically, I just want to see how you guys would approach this, what would be a systematic way to solve it? This wasn't even a challenge question and I got destroyed by it.
EDIT: Also, I'm unsure about my reasoning. I was more happy with the way I did it last time.
If [tex]A=A^{-1}[/tex], then [tex]A^2=I[/tex]. From that, I derived the following equations:
(i) [itex]a^2+bc=1[/itex]
(ii) [itex]ab+bd=0[/itex]
(iii) [itex]ac+cd=0[/itex]
(iv) [itex]d^2+bc=1[/itex]
Subtract equation (iv) from equation (i).
That gives [itex]d=\pm\,a\ .[/itex]
What do equations (ii) & (iii) tell you ?
Well there is a quick way of finding the inverse of a 2x2 matrix
[tex]A= <br /> \begin{bmatrix} <br /> a & b <br /> \\ c & d <br /> \end{bmatrix}[/tex]
[tex]A^{-1}=\frac{1}{det(A)}*adj(A)[/tex]
and the adjugate of a 2x2 matrix is just
[tex] \begin{bmatrix} <br /> d & -b <br /> \\ -c & a <br /> \end{bmatrix}[/tex]
the determinant is [tex]ad-bc[/tex]
which by equating elements of the matrix and it's inverse you can show [tex]ad-bc=-1[/tex] and that [tex]d=-a[/tex]
and from here getting the rest of the solution isn't too complicated.
\begin{bmatrix}
1 & 0
\\ 0&1
\end{bmatrix}
\begin{bmatrix}
-1 & 0
\\ 0&-1
\end{bmatrix}
[/tex]
[tex]ab+bd=0[/tex]
[tex]b(a+d)=0[/tex]
[tex]b=0[/tex]
Something you will find useful over and over again is a simple rule for inverting a 2x2 matrix:
swap the diagonal elements, change sign of the off-diagonal elements, and divide by the determinant. (Others have displayed this for you, but expressing it in words may help.)
RGV
Hi autodidude! :smile:
If you're interested in alternative and simpler ways to solve it, here's another (although it does require some advanced knowledge :wink:).Since you have ##A^2-I=0##, according to Cayley–Hamilton, the eigenvalues of A must be roots of ##x^2-1=0##.
So the eigenvalues can only be ##\pm 1##.And according to Jordan, the possible matrices A must then be "similar" to one of:
J = \begin{bmatrix}1&0\\0&1\end{bmatrix},\
\begin{bmatrix}-1&0\\0&-1\end{bmatrix},\
\begin{bmatrix}1&0\\0&-1\end{bmatrix},\
\begin{bmatrix}1&1\\0&1\end{bmatrix},\
\begin{bmatrix}-1&1\\0&-1\end{bmatrix}
However not all of these matrices are a solution: the last 2 do not "fit", which you can verify by calculating ##A^2##, or by finding the inverse as mentioned before (swapping the entries on the main diagonal, negating the other 2 entries, and dividing by the determinant).The term "similar" means that for any invertible matrix B, the matrix product ##A = B J B^{-1}## is a solution.
In the cases that J=I or J=-I, you can see that the corresponding matrices simplify to ##A=B I B^{-1}=I##, respectively ##A=B \cdot -I \cdot B^{-1}=-I##.So the solutions with any invertible matrix B are:
A = I,\
A = -I,\
A = B \begin{bmatrix}1&0\\0&-1\end{bmatrix} B^{-1}
I did manage to get ad-bc = -1 the second time I did it. I think the part that wasn't supposed to be complicated turned out to be very complicated for me :)
@I like Serena: I'm very interested in other methods...but yeah, that's beyond where I'm at the moment. Looks much nicer :p
