MHB How can I find the area of a triangle with a given angle and two sides?
  • Thread starter Thread starter xyz_1965
    Area Triangle
The area of a triangle with an angle of 70° between two sides measuring 6 cm and 4 cm can be calculated using the formula A = 1/2 * a * b * sin(C). Substituting the values, the area is determined to be approximately 11.28 cm². The sine function is utilized to find the length of the opposite side, confirming the use of the SOH-CAH-TOA mnemonic. The discussion also mentions the applicability of the law of sines and the law of cosines for further calculations.
  • Understanding of trigonometric functions, specifically sine
  • Familiarity with the area formula for triangles: A = 1/2 * a * b * sin(C)
  • Basic knowledge of angles in degrees
  • Concept of the law of sines and law of cosines
  • Study the law of sines for solving non-right triangles
  • Explore the law of cosines for calculating unknown sides and angles
  • Practice using the sine function in various triangle problems
  • Learn about the properties of triangles and their area calculations
Students studying trigonometry, educators teaching geometry, and anyone needing to calculate the area of triangles using trigonometric principles.
xyz_1965
Find the area of a triangle with angle 70° in between sides 6 cm and 4 cm.
Solution:
From the SOH-CAH-TOA mnemonic, I want the ratio of the opposite side (CD) to the hypotenuse (AC). I should be using the *sine* function, not cosine. Yes?
SOH leads to sin = opp/hyp
sin(70°) = CD/4
CD = 4 sin(70°)
Here is the rest:
Area = 12 sin(70°)
≈ 12 * 0.9396
Answer:
≈ 11.28 cm^2
Yes?
Mathematics news on Phys.org
I would use:
$$A=\frac{1}{2}ab\sin(C)$$
Using the given data:
$$A=\frac{1}{2}(6\text{ cm})(4\text{ cm})\sin(70^{\circ})$$
Looks good.
MarkFL said:
I would use:
Looks good.
I know the law of sines or law of cosines could be applied here. This is the next chapter in my studies.
