Find constants a and b for f(x) differentiability
  • Thread starter Thread starter souldoutt
    Differentiability
5 replies · 23K views
souldoutt
Find the values of the constants a and b such that the function f(x) is differentiable on R
f(x) = ax2 if x < 2
f(x) = -4(x-3) + b if x >= 2
ax2 = -4(x-3) + b
2xa = -4x
a = -2
I believe that I need to equate the equations but with a value of a how do I find b and then prove that it's differentiable?
Welcome to PF!
Hi souldoutt! Welcome to PF! :smile:
(however did you get 2xa = -4x? :confused:)
Hint: the only problem is at x = 2.
So just bung x = 2 in, and check for continuity and differentiability. :smile:
I got the 2xa = -4x by differentiating both sides.
But with 2 separate unknown constants, how would i solve for them? I can plug the value x = 2 into the equations but i won't get an answer to confirm whether the second part of the function is actually starting from x = 2.
Then wouldn't I still need to have the constants in order to check whether the slopes of the tangents are the same? (therefore differentiable)?
thanks for the welcome too.
Hi souldoutt! :smile:
For continuity, if you put x = 2, you get f(2) = 4a and = 4 + b,
so your continuity equation is 4a = 4 + b.
And similarly for differentiability you get f'(2) = 4a = -8.
So … ? :smile:
f(x) = ax2 if x < 2
ax2 = -4(x-3) + b
2xa = -4x
a = -2
Yes, a must be -2. Now, you put a= -2 and x= 2 in the first equation you have -4= 4+ b. Solve for b.
To prove it is differentiable, with the correct values for a and b, Look at the difference quotient limit.
It should be -8 instead of -4 right? Because it is ax2 which = -8 when the numbers are plugged in.
Then, once I have the values of a and b the difference quotient limit to check for differentiability is the difference quotient limit of the derivatives correct?
