Find Equilibrant Force Using Trig Method
  • Thread starter Thread starter nikmar
    Force
2 replies · 29K views
nikmar
force system a:
force no. 1: 5.0N at 0 deg
force no. 2: 5.0N at 90 deg
force system b:
force no. 2: 5.0N at 60 deg
force system c:
force no. 1: 5.0N at 30 deg
force no. 2: 5.0N at 150 deg
how do you find the equilibrant force using the trigonometric method? Do you multiply the force 1 (5.0) times cos 0 deg; force 2 (5.0) times cos 90 deg; etc?:confused:
Well, you have a few systems consisting of two forces here. Now, for every system, i.e. for every couple of forces, you must consider the resultant force, which is the sum of the two forces of a system. For example, for the system a, you have [tex]\vec{R}=\vec{F}_{1}+\vec{F}_{2}=5\vec{i}+5\vec{j}[/tex]. So, the force which will set the system of equilibrium is a force with the same magnitude as the resultant force R, but pointing in the opposite direction. Now you have a clue.
