Find First Free Position in Array in $O(\log n)$ Time Complexity
  • Context:
  • Thread starter Thread starter mathmari
    Position
36 replies · 7K views
mathmari
MHB
Hey! :o
I want to merge two arrays.
How can I find the first free position of the first array in time complexity $O(\log n)$ ?? (Wondering)
mathmari said:
Hey! :o
Hi! (Smile)
How about a binary search? (Thinking)
I like Serena said:
Hi! (Smile)
I have done the following:
Code:
int FreePos(int *A, int low, int high){
	int mid=low+floor((high-low)/2);
	if(high<low){
		return -1;
	if(A[mid] == INT_MAX){
		if(A[mid-1] != INT_MAX){
			return mid -1;
		else{
			FreePos(A, low, mid-2);
	else{
		if(A[mid+1] == INT_MAX){
			return mid;
		else{
			FreePos(A, mid+2, high);
Is it correct?? (Wondering)I need this function for a function that combines two star systems, the "ss1" and "ss2".
The combination of the lists of the planetary systems should be done in time $O(1)$.
For the combination of the arrays of the free-floating planets we have to find the first free element of the first array, that should be done in time $O(\log n)$.
At the end the star system with identifier "ss2" should be deleted from the array of star systems, and at the position of the deleted star system we insert the star system that is at the last position of the array.
Code:
int SolarSystem_Combiner(int ss1, int ss2){
	int i, k, m, pos1, pos2;
	for(i=0; i<Sfreep; i++){
			if(StarS[i].ss1==ss1){
				k=i;
			if(StarS[i].ss2==ss2){
				m=i;
	StarS[k].Sentinel->next=StarS[m].plasy;
	StarS[k].Sentinel=StarS[m].Sentinel;
	pos1=FreePos(StarS[k].ffplan, 0, max);
	pos2=FreePos(StarS[m].ffplan, 0, max);
	for(i=0; i<pos2; i++){
		StarS[k].ffplan[pos+i]=StarS[m].ffplan[i];
	return 0;
How can I delete the star system with identifier "ss2" from the array of star systems?? (Wondering)
mathmari said:
Code:
	if(high<low){
		return -1;
			return mid -1;
		else{
	else{
			return mid;
		else{
Let's check a couple of edge cases. (Nerd)
What would you get in each of the following cases:
Code:
int A[1] = {1};                FreePos(A, 0, 0);
int B[1] = {INT_MAX};          FreePos(B, 0, 0);
int C[2] = {1, 2};             FreePos(C, 0, 1);
int D[2] = {INT_MAX, INT_MAX}; FreePos(D, 0, 1);
(Wondering)
Code:
(Wondering)
I made some changes...
Code:
	if(high<low){
		return -1;
	if(low==high){
		if(A[low] == INT_MAX){
			return low;
		else{
			return low+1;
	else if(A[mid] == INT_MAX && mid-1>=low){
			return mid -1;
		else{
			if(mid-2 >= low){
			else{
				return mid-2;
	else if(A[mid] != INT_MAX && mid+1<=high){
			return mid;
		else{
			if(mid+2 <= high){
			else{
				return mid+2;
Is it better now?? (Wondering)
Code:
	if(high<low){
		return -1;
	if(low==high){
			return low;
		else{
			return low+1;
			return mid -1;
		else{
			if(mid-2 >= low){
			else{
				return mid-2;
			return mid;
		else{
			if(mid+2 <= high){
			else{
				return mid+2;
How about:
Code:
int E[] = {INT_MAX, INT_MAX, INT_MAX};
(Wondering)
As a suggestion, perhaps remove all if statements from the recursive cases? (Wasntme)
I like Serena said:
How about:
Code:
(Wondering)
I tried it again...
Code:
	if(high<low){
		return -1;
	if(A[0] == INT_MAX){
		return 0;
	if(A[high] < INT_MAX){
		return high+1;
	if(A[mid] < INT_MAX){
			return mid+1;
		else{
			return FreePos(A,  mid+2, high);
	else{
		if(A[mid-1] < INT_MAX){
			return mid-1;
		else{
			return FreePos(A, low, mid-2);
mathmari said:
I tried it again...
Code:
	if(high<low){
		return -1;
		return 0;
		return high+1;
			return mid+1;
		else{
	else{
			return mid-1;
		else{
I'm afraid that the way you had it, you did need those extra if conditions.
Otherwise you'll be accessing the array outside of its bounds, which would cause a segmentation violation. (Worried)
I'm suggesting something more like this:
Code:
	<Final cases>
		return FreePos(A, low, mid);
	else{
		return FreePos(A,  mid+1, high);
(Thinking)
Code:
	<Final cases>
	else{
(Thinking)
Is the final case when we have an array with only one element, and we have to check if it is INT_MAX or not?? (Wondering)
Yes! (Nod)
The case [m]high < low[/m] should not even occur, although it won't hurt to handle it anyway.
I like Serena said:
Yes! (Nod)
So, should it be as followed??
Code:
	if(high<low){
		return -1;
	if(low == high){
			return low;
		else{
			printf("There is no free position.\n");
			return -1;
	else{
(Wondering)
Code:
	if(high<low){
		return -1;
	if(low == high){
			return low;
		else{
			return -1;
	else{
(Wondering)
Almost. (Thinking)
Remember that the range low to high is a sub range in the actual array.
If, in the final case, A[low] != INT_MAX, it means that the first free element comes after.
And if the array is completely full, the function will return the index after the last valid one.
It is good programming practice to document this behavior in comments above the function. And when we call the function, we need to ensure that case is handled. (Nerd)
Do you mean that I should do it as followed??
Code:
	if(high<low){
		return -1;
	if(low == high){
			return low;
		else{
			return low+1;
	else{
(Wondering)
Code:
	if(high<low){
		return -1;
	if(low == high){
			return low;
		else{
			return low+1;
	else{
(Wondering)
Yep! (Smile)
I like Serena said:
Yep! (Smile)
Great! (Yes)
I have written a function for the combination of the two star systems.
When I call the function FreePos() as followed:
[m]pos=FreePos(StarS[k].ffplan, 0, max);[/m]
I get a segmentation fault because of the first argument of the function.
What should I change?? (Wondering)
I you get a segmentation fault, it means one (or more) of the following:
  1. k is out of range to index StarS,
  2. ffplan does not behave like an array,
  3. ffplan is an array, but it does not have (max - 0 + 1) elements,
  4. there is still a mistake in the code of Freepos.
How can we eliminate each of these possibilities? (Thinking)
  1. I found k as followed:
    Code:
    			if(StarS[i].ss==ss1){
    				k=i;
    So, k is not out of range to index StarS, right?? (Wondering)
  2. The definition of ffplan is:
    Code:
    struct starsy {
     int ss;               /*Identifier of the star system*/
     plansys_t *plasy;     /*Pointer to the first element in the list of the planetary system */
     ffplan_t ffplan[max];     /*The array of the free-floating planets */
     plansys_t *Sentinel;      /*Pointer to the sentinel node of the list of the planetary system */
    So, isn't it an array?? (wondering)
  3. How can I check that?? (Wondering)
  4. (Worried)(Sweating)
[m]k[/m] is guaranteed to be in range if [m]Sfreep[/m] is.
How can you tell that it is? (Wondering)
[*]The definition of ffplan is:
Code:
struct starsy {
Check! $\checkmark$
[*]How can I check that?? (Wondering)
Well, the algorithm (as it is now) expects [m]high[/m] to be the highest valid index in the array.
... but [m]max[/m] is not a valid index in the array, it is one higher.
So this might cause a segmentation fault.
Either we have to adapt the algorithm, or we have to pass [m]max - 1[/m].
[*](Worried)(Sweating)
The way to do it, is to test the function against a series of boundary conditions.
Like:
Code:
int main() {
  assert(-1 == FreePos(NULL, 0, -1));
  int A[1] = {1};
  assert(1 == FreePos(A, 0, 0));
  assert(0 == FreePos(B, 0, 0));
  int C[2] = {1, 2};
  assert(2 == FreePos(C, 0, 1));
  int D[2] = {1, INT_MAX};
  assert(1 == FreePos(D, 0, 1));
  int E[2] = {INT_MAX, INT_MAX};
  assert(0 == FreePos(E, 0, 1));
  int F[3] = {INT_MAX, INT_MAX, INT_MAX};
  assert(0 == FreePos(F, 0, 2));
  int G[3] = {1, INT_MAX, INT_MAX};
  assert(1 == FreePos(G, 0, 2));
  int H[3] = {1, 2, 3};
  assert(3 == FreePos(H, 0, 2));
  return 0;
Can this code compile and run successfully? (Wondering)
This is called "unit testing".
Alternatively, you could print all the elements in ffplan beforehand.
Then figure out for yourself what the return value of FreePos() should be.
And perhaps print a couple of intermediate results in FreePos() to verify if it runs as you expect.
This is called "debugging". (Nerd)
I added an if statement at the following function:
Code:
int Constitution(int ss) {
        int i;
        starsy_t *starsystem = &StarS[Sfreep];
        Sfreep++;
        if(Sfreep>N){
	        return -1;
        starsystem->ss = ss;
        starsystem->plasy=starsystem->Sentinel;
	for(i=0; i<max; i++){
		starsystem->ffplan[i].fp=INT_MAX;
		starsystem->ffplan[i].ff=NULL;
	return (Sfreep - 1);
Now, [m]Sfreep[/m] is guaranteed to be in range, right?? (Wondering)
You're right!
I changed that, and now I call the function as followed:
[m]pos=FreePos(StarS[k].ffplan, 0, max-1);[/m]
But, I still get the following error:
[m]warning: passing arg 1 of 'FreePos' from incompatible pointer type[/m]
Like:
Code:
int main() {
  int A[1] = {1};
  int C[2] = {1, 2};
  return 0;
I ran the program and the result are the correct ones! (Emo)
Hi,
The following version of binary search is nothing new, but it does do exactly what you want. It returns the index of the first occurrence of the search argument. If you're up to it, you might try and prove the correctness of the algorithm. Also you might try to modify the function so that the return is the last occurrence of the search argument.
Code:
/* Upon entry the array a of n components is sorted.  x is a search
   argument.  If x occurs as a component of the array, the return is the
   FIRST index i with a[i]==x; i.e. for j<i, a[j]!=x.  If x is not a
   componet, return is -1.
int binarySearch(int *a,int n,int x) {
    int lo=0,hi=n-1,mid;
    while (lo<hi) {
        mid=(lo+hi)/2; // in C, this is floor(a+b/2)
        if (a[mid]<x) {
            lo=mid+1;
        else {
            hi=mid;
    if (a[hi]==x){
        return(lo);
    else {
        return(-1);
Code:
        int i;
        Sfreep++;
        if(Sfreep>N){
	        return -1;
Whether it fits or not, [m]Sfreep[/m] is still incremented, isn't it? (Wondering)
So no, I don't think it is guaranteed to be in range.
Aaaah.
Argument 1 of FreePos() is an [m]int*[/m], and you're passing a [m]ffplan_t*[/m] and they do not match.
What happens if you change the type? (Wondering)
Nice! (Smile)
What can I do so that it is guaranteed to be in range?? (Wondering)
I like Serena said:
Aaaah.
Argument 1 of FreePos() is an [m]int*[/m], and your passing a [m]ffplan_t*[/m] and they do not match.
I changed it, and I changed [m]A[low][/m] to [m]A[low].fp[/m].
Now, there is no segmentation fault! (Party)
Only increment Sfreep if Sfreep < N.
Then, after a failure to add a new star system, Sfreep will still be N.
(drink)
Do you mean that it should be as followed??
Code:
        int i;
        while(Sfreep<N){
        	Sfreep++;
(Wondering)
Code:
        int i;
        while(Sfreep<N){
        	Sfreep++;
(Wondering)
That should be an "if" instead of a "while".
And if there is no more space, the function should return immediately. (Worried)
So should it be as followed??
Code:
if(Sfreep<N){
        	Sfreep++;
		if(Sfreep>=N){
			exit();
(Wondering)
Code:
if(Sfreep<N){
        	Sfreep++;
		if(Sfreep>=N){
			exit();
(Wondering)
Something like that.
Does it compile? (Wondering)
No, I get the following error:
[m]error: `starsystem' undeclared (first use in this function)[/m](Wondering)
I like Serena said:
What do you think is wrong? (Thinking)
Should I declare [m]starsystem[/m] outside the if?? (Wondering)
