Find Fourier Series for Piecewise Function
  • Context:
  • Thread starter Thread starter Dustinsfl
    Fourier
3 replies · 2K views
Dustinsfl
Find the Fourier series for
f(\theta) = \begin{cases}
\theta, & 0\leq \theta \leq\pi\\
\pi + \theta, & -\pi\leq \theta < 0
\end{cases}.
a_0 = \frac{1}{\pi}\int_0^{\pi}\theta d\theta + \frac{1}{\pi}\int_{-\pi}^0\theta d\theta + \int_{-\pi}^0 d\theta
The first and second integral together are 0 so the $a_0 = \pi$
a_n = \frac{1}{\pi}\int_0^{\pi}\theta\cos n\theta d\theta + \frac{1}{\pi}\int_{-\pi}^0\theta\cos n\theta d\theta + \int_{-\pi}^0 \cos n\theta d\theta
The first and second integral together are 0 so the $a_n = 0$
b_n = \frac{1}{\pi}\int_0^{\pi}\theta\sin n\theta d\theta + \frac{1}{\pi}\int_{-\pi}^0\theta\sin n\theta d\theta + \int_{-\pi}^0\sin n\theta d\theta
The first and second integral together are 0 so the $b_n = \begin{cases}\frac{-2}{n}, & \text{if n is odd}\\0, & \text{if n is even}\end{cases}$
So
\frac{\pi}{2} - 2\sum_{n = 1}^{\infty}\frac{1}{2n-1}\sin(2n - 1)\theta
Correct?
So
Correct?
Hi dwsmith, :)
I think you have made a little error. As you can see \(g(\theta)=\theta\sin n\theta=g(-\theta)\). Therefore \(g\) is an even function. Hence,
\[b_n = \frac{1}{\pi}\int_0^{\pi}\theta\sin n\theta d\theta + \frac{1}{\pi}\int_{-\pi}^0\theta\sin n\theta d\theta + \int_{-\pi}^0\sin n\theta d\theta= \frac{2}{\pi}\int_0^{\pi}\theta\sin n\theta d\theta + \int_{-\pi}^0\sin n\theta d\theta\]
Kind Regards,
Sudharaka.
So the Fourier series is
\frac{\pi}{2} - 2\sum_{n = 1}^{\infty}\frac{1}{2n}\sin(2n)\theta.
Correct! You can check that this formula works by using the excellent Desmos graphing application that now comes for free with MathHelpBoards. See the graph below. In fact, click on the graph and you will see the formula used to generate it. Use the slider to see the sum of up to 20 terms of this Fourier series, and notice how it converges to the midpoint of each jump in the graph.
[graph]ymrd1ovgce[/graph]
