Find moment of inertia via torque and acceleration parameter
The discussion focuses on calculating the moment of inertia of a motor given a constant torque of 4 Nm and a speed of 1717 rpm reached in 4 seconds. The relevant equations include T = J(eff) * dw/dt and J = kg*M^2, where J represents moment of inertia. The confusion arises from the units of moment of inertia being stated as Nm·s², which is clarified as equivalent to kg·m². The user successfully identifies how to calculate dw/dt, indicating a resolution to their initial uncertainty.
  • Understanding of torque and its units (Nm)
  • Familiarity with rotational dynamics and moment of inertia
  • Basic knowledge of angular velocity and its calculation
  • Proficiency in applying Newton's second law for rotation
  • Study the relationship between torque, moment of inertia, and angular acceleration
  • Learn how to convert between different units of angular velocity (e.g., rpm to rad/s)
  • Explore the implications of damping in motor dynamics
  • Investigate advanced topics in electric drives and motor control systems
Students in mechanical engineering, particularly those studying electric drives, as well as professionals involved in motor design and analysis.
D.B0004
2-1. A constant torque of 4 Nm is applied to an unloaded motor at rest at time t = 0. The motor reaches a speed of 1717 rpm in 4 s. Assuming the damping to be negligible, calculate the motor inertia in Nm·s2.
T = J(eff) * dw/dt
J = kg*M^2
I have NO clue where to start. First question - why is the motor inertia units stated as Nm*S2? I thought moment of inertia was only kg*m^2 (m = meters).
Second question - can someone point me in the right direction? I have been reading for hours. I know this is simple I'm just missing a link. Thanks for the help.
Also the problem seems basic but I posted it in this section because its for a 4000 level course - Electric Drives. Let me know if it should be elsewhere.
1 N = 1 kg * 1 ms-2
In your first relevant equation, how would you calculate dw/dt?
Wow. I feel like an idiot. Got it. Thanks.
15K
  • · Replies 18 ·
