Find position function of freefall with air resistence ODE
7 replies · 5K views
1s1
An object of mass ##5##kg is released from rest ##1000##m above the ground and allowed to fall under the influence of gravity. Assuming the force due to air resistance is proportional to the velocity of the object with proportionality constant ##b=50##N-sec/m, determine the equation of motion (for the position ##x(t)##) of the object.
$$m\frac{dv}{dt} = mg-kv$$
The given differential equation describes the velocity with respect to time. How do I turn it into a differential equation that describes the position with respect to time?
Your relevant equation is a bit off, shouldn't it read ##m\frac{dv}{dt} = (-1)(mg+kv)##?
If that's the case then solving it with the constraint that ##v(0) = 0## should simplify things a bit.
You may be right about the relevant equation being negative on the RHS. My book has it written as I did, but my prof mentioned that physicists sometimes make sign changes to the constant.
But I am still confused about how to make the function into a function of position? I assume you use the relationship ##d=vt##? Or maybe there is an entirely different formula derived for the position rather than the velocity?
Notice this was part of your question:
An object of mass 5kg is released from rest
This means at ##t=0##, the velocity of the object is zero. That's why I mentioned solving the equation with the constraint ##v(0) = 0##. Right now you have an acceleration equation since it involves derivatives of velocity, but if you integrate acceleration, you get velocity;if you integrate vel...
the sign is given by the direction of the [itex]x[/itex] axis. If you define it to point "down", i.e., in direction of the constant gravitation force, the positive sign [itex]+mg[/itex] is correct. The sign in [itex]-k v[/itex] (assuming [itex]k>0[/itex]) is the same for both directions of the [itex]x[/itex] axis, because the friction force must always be such that it tends to decrease [itex]v[/itex].
Further note, that you have a nice inhomogeneous linear differential equation of first order with constant coefficients, which is pretty easy to solve by separation of variables. The gives you [itex]v(t)[/itex].
Then you have to solve another very simple equation
[tex]v=\frac{\mathrm{d} x}{\mathrm{d} t}.[/tex]
Given [itex]v[/itex], it's very clear, how to get [itex]x(t)[/itex]!
Why? Air RESISTANCE implies that it will go against the direction of acceleration. This is a physics problem, primarily.
We're supposed to solve the equation and make a position function, right? I will denote ##\frac{dv}{dt}## as ##v'##, for clarity and ease of notation (id est, laziness. It's a friday. Give me a break :-p).
I'm assuming we have ##k=b##, right? So, we have $$mv'=mg-bv \\ v' +\frac{b}{m}v=g.$$ In this form, we can introduce an integrating factor. Can you take it from there?
Edit: vanhees71 got there first by noting the inhomogeneous equation.
Indeed. Finding ##\Gamma(x(t)+1)## is easy once we have ##v##. :biggrin:
This is very helpful, thanks!
I suppose it depends on how you decide to define up and down.
For me that's dependent on the day of the week :P.
