Find Ratio of vb/vc for Person Homework Statement
  • Thread starter Thread starter lpcampbe
The discussion focuses on calculating the ratio of recoil speeds (vb/vc) for a person firing a gun on a frictionless surface. When a standard cartridge fires a 17g bullet at 280 m/s, the recoil speed is vc, while a blank cartridge fires a 0.13g mass at 53 m/s, resulting in recoil speed vb. The conservation of momentum principle is applied, leading to the conclusion that the ratio of the speeds can be determined by the inverse ratio of their respective masses, given that the mass of the person remains constant throughout the experiment.
  • Understanding of momentum conservation principles
  • Familiarity with kinetic energy calculations
  • Basic knowledge of mass and velocity relationships
  • Ability to apply physics equations in problem-solving
  • Study the conservation of momentum in closed systems
  • Learn about the relationship between mass and velocity in recoil scenarios
  • Explore kinetic energy calculations for different types of ammunition
  • Investigate real-world applications of momentum conservation in physics
Students studying physics, particularly those focusing on mechanics and momentum, as well as educators seeking to explain recoil effects in firearms.
lpcampbe
A person is standing on a sheet of ice so slippery that friction may be ignored. This individual fires a gun parallel to the ground. When a standard cartridge is used , a 17-g bullet is shot forward with a speed of 280 m/s, and the person recoils with a speed of vc. When a blank cartridge is used , a mass of 0.13g is shot forward with a speed of 53 m/s , and the recoil speed is vb. Find the ratio vb/vc.
mass of bullet = 0.017 kg
mass of blank = 1.3e-4 kg
KE = 1/2mv^2 ?
I tried using that equation and solved for KE of the bullet (666.4 J) and the KE of the blank (0.1825 J) but I don't know if that's useful or not. I'm not given the mass of the person, and I don't just want to assume 60 kg. I know I'm supposed to attempt to do the problem before asking for help, but I don't even know where to start.
Here, remember that momentum is always conserved. Because of this, you can say that the total momentum change is 0.
Also keep in mind that the mass of the man never changes in either situation. Think about this.
The kinetic energy (KE) would not be helpful here, becase chemical energy is being converted into kinetic energy when the gun is fired. Momentum, however, is helpful.
Think of the system (man plus pistol plus bullet) splitting in two. The two parts (man plus pistol) and (bullet) will have equal but opposite momenta. Their speeds will therefore be in the inverse ratio of their masses. In practice, the bullet would be so small, that the man and his paraphernalia may be assumed to have the same mass throughout the experiment.
  • · Replies 23 ·
10K
  • · Replies 22 ·
