Find tension in a rope of a mountain climber
  • Thread starter Thread starter 1irishman
    Rope Tension
The discussion revolves around calculating the tension in a rope for a 735N mountain climber rappelling down a vertical cliff at a 12-degree angle with the vertical. The climber's weight and the tension's components are analyzed using the equations of motion and trigonometric functions. The correct tension in the rope, as stated in the reference material, is 751N. The participants clarify that there is no frictional force acting on the climber, as he is not sliding down the cliff.
  • Understanding of Newton's second law (Fnet=ma)
  • Knowledge of trigonometric functions and their applications
  • Familiarity with force components and vector resolution
  • Basic principles of static equilibrium in physics
  • Study the application of Newton's laws in static and dynamic scenarios
  • Learn about vector resolution and how to decompose forces into components
  • Explore the role of friction in climbing and rappelling scenarios
  • Investigate the effects of angles on force calculations in physics problems
This discussion is beneficial for physics students, mountain climbing instructors, and anyone interested in understanding the mechanics of tension in climbing scenarios.
1irishman
A 735N mountain climber is rappelling down the face of a vertical cliff as shown in the diagram. If the rope makes an angle of 12deg with the vertical face, what is the tension in the rope?
Fnet=ma
trig functions
Ff=uFN
I separated force into x and y components
X
FN-Tx=0
therefore FN=Tx
Y
Ff+Ty-mg=0
Ff=uFN=uTx
uTx+Ty-mg=0
uTcos78+Tsin78-mg=0
I need help from here...the answer in the book says 751N, so i don't know...maybe i setup my net force equation wrong?
The mountain climber is repelling down the mountain, not sliding down the mountain. Consider this when deriving your equations.
Oh, so does that mean no friction force then? Or does that mean I need to change a positive sign to a negative sign in one or more of my equations? Thank you.
\mu_s isn't a given quantity, if you need it, where are you going to get it from?
there will be no frictional force
correct ^^
I'm lost...i think the angle to use with the trig functions is 78deg, but I'm not sure...i'm not sure how to proceed further...
ok, what do we know?
we know that the tension force has two components and we know that its y-component must equal (mg) in order for the man not to accelerate downward.
we know that the force of the mountain on the man must equal the x-component of the tension force in order for the man not to accelerate through the mountain.
we have the adjacent side of our force vector and we have the angle between the adjacent and the hypotenuse. Can you take it from here?
I will try and get back...thank you for help.
my pleasure, keep in mind that cosine is defined adjacent over hypotenuse.
  • · Replies 18 ·
9K
10K
