Find The Area of A Quadrilateral
  • Thread starter Thread starter LLS
    Area
The problem involves finding the area of a quadrilateral PQTS formed within a square PQRS, where T is the midpoint of side QR. The area of the square is given as 3.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss various methods to calculate the area of the quadrilateral, including geometric reasoning and arithmetic checks. Some question the arithmetic in the original calculation and suggest visualizing the problem with diagrams. Others explore the relationship between the areas of triangles and the square.
There are multiple interpretations of the area calculations, with some participants suggesting different approaches and questioning the arithmetic of earlier attempts. Guidance has been provided regarding the geometric properties of the shapes involved, but no consensus has been reached on the final area of the quadrilateral.
Participants are working under the constraints of the problem as stated, with some expressing uncertainty about their calculations and the assumptions made regarding the geometry of the square and the quadrilateral.
LLS
The Area of A Quadrilateral Given A Square
In a square PQRS, point T is the midpoint of side QR. If the area of square PQRS is 3, what is the area of quadrilateral PQTS?
area = 1/2 base * height
Side QR = 1.737
Side RS = 1.737
TR = .8685
area = 1/2(1.737) * .8685 = .25
The area of the triangle = .25
3 - .25 = 2.75
The area of quadrilateral PQTS = 2.75
Is my answer right?
Check your arithmetic here: you have one-half of a number close to 1.8, which you multiplied by a number close to 0.9, and got 0.25...(?)
I have another suggestion. Draw a picture of this square with the line segment PT added. What is the area of triangle PQT? (Incidentally, because of the symmetry of the geometry here, you don't even need to use the formula for the area of a triangle.)
Now, the quadrilateral PQTS is made up of half the square plus a triangle of the same area as PQT. So what would this quadrilateral's area be?
Sometimes it's easier to stick with whole numbers and fractions:
length of side = [tex]\sqrt{3}[/tex]
length of QT = [tex]\frac{1}{2}[/tex][tex]\sqrt{3}[/tex]
area of triangle QTS = [tex]\frac{1}{2}[/tex]*[tex]\frac{\sqrt{3}}{2}[/tex]*[tex]\sqrt{3}[/tex]
=[tex]\frac{\sqrt{3}}{2}[/tex]*[tex]\frac{\sqrt{3}}{2}[/tex]
and what does [tex]\sqrt{3}[/tex]*[tex]\sqrt{3}[/tex] = ?
divide that by 4 (1/2 * 1/2) for your answer.
Then take that away from 3.
√3*√3 = 3
3 - 3/4 = 2.25
The quad = 2.25?
I don't think that answer is correct.
I may have mad a mistake in the math. Is the answer 2.75?
The triangle you are describing has one-quarter the area of the square. (Take the midpoint on the side opposite QR, which is PS. A line straight from T to that other midpoint divides the square in two. The line from P to T divides that rectangle in half diagonally, so triangle PQT has one-quarter of 3 units or 0.75.
The quadrilateral PQTS is made up of the upper half of the square plus a triangle with the same area as PQT. So it has three-quarters of the area of the whole square or
(3/4) · 3 = 2.25 units.
Thank you
  • · Replies 27 ·
  • · Replies 17 ·
