Calculating the Diameter of a Drilled Hole in a Revolved Solid
  • Thread starter Thread starter icesalmon
    Diameter Hole
The discussion centers on calculating the diameter of a drilled hole in a solid generated by revolving the region bounded by the equations y = x²/2 and y = 2 around the y-axis. The user initially attempted to use cylindrical shells for volume integration, arriving at a total volume of 4π/3. After determining that one-fourth of this volume is removed, they aimed to relate the volume of the hole to its dimensions, ultimately concluding that the diameter can be expressed as 2(√(y/2)). The correct value for 'a', representing the radius of the hole, was found to be √2.
  • Understanding of volume integration using cylindrical shells
  • Familiarity with the equations of curves and solids of revolution
  • Knowledge of calculus, specifically integration techniques
  • Ability to manipulate algebraic expressions and solve equations
  • Study the method of cylindrical shells in volume calculations
  • Learn about solids of revolution and their properties
  • Explore advanced integration techniques in calculus
  • Investigate the relationship between volume and dimensions in geometric figures
Students studying calculus, particularly those focusing on volume calculations and solids of revolution, as well as educators seeking to enhance their teaching methods in these topics.
icesalmon
A solid is generated by revolving the region bounded by y = x2/2 and y = 2 around the y-axis. A hole, centered along the axis of revolution, is drilled through this solid so that one-fourth of the volume is removed. Find the diameter of the hole.
I'm going with cylindrical shells this time around. I'm integrating from x = 0 to x = 2. I think my height is 2-x and my radii are all going to be generated by the function x2/2. After integration, I get the overall volume is to be 4pi/3. If one quarter of that is taken out after drilling this hole, I have the volume of this figure to be pi. I believe it's a right cylindrical shaped whole, so the volume of a cylinder is pir2h. I need the radius of one of these cross sections so I need some way to relate the volume. Or maybe I don't, this is where I need assistance. Hopefully I'm not over-thinking this. Thanks.
I believe I've made a mistake on the radius / height. Radius = x and Height = x2/2, after integration I get vt = 4pi so the volume of the cylinder is 3pi.
Yes, except that the removed core is not exactly a cylinder. What do you get for the diameter of the hole?
I don't know how to find it, especially since I don't know what the figure of the hole is.
Edit: the diameter seems like it would be 2(y/2)1/2 but that's sort of a shot in the dark.
Edit: that's wrong, nvm.
The height of each shell should be 2 - x2/2 .
Do the same integral but have x go from 0 to a. set that volume to 1/4 the volume without the hole & solve for a .
I'm getting two answers..2 and 2(21/2)
and neither are correct.
Should have included this, sorry. My integrand here has been changed to (x)(2-x2/2). When my bounds are [0,a] I get 2pi(a2 - a4/8). When my bounds are [0,2] I get the volume as 4pi. If I set the first part equal to 1/4 of the total volume I get 2pi(a2 -a4/8) = pi and I solve it from there to get that a = 21/2
icesalmon said:
2pi(a2 -a4/8) = pi
Right
a = 21/2
Wrong.
thanks, got it now.
