Find the equilibrium concentration
The discussion centers on calculating equilibrium concentrations for the reaction 3NO → N2O + NO2 at 300 K, where Kp is given as 1.5 x 1018. The participant successfully converted Kp to Kc, yielding a value of 6.08 x 1016, and established the mass action expression using an ICE chart. However, they encountered difficulties in solving for x due to the complexity of the equation. The consensus is that with such a high Kc value, the reaction proceeds nearly to completion, suggesting that stoichiometric calculations may be more appropriate than an ICE chart.
  • Understanding of chemical equilibrium concepts
  • Familiarity with Kp and Kc conversions
  • Proficiency in using ICE charts for equilibrium calculations
  • Knowledge of stoichiometry in chemical reactions
  • Study the conversion between Kp and Kc in detail
  • Learn how to effectively use ICE charts for complex reactions
  • Research conditions under which reactions can be assumed to go to completion
  • Explore advanced stoichiometric techniques for equilibrium problems
Chemistry students, educators, and professionals involved in chemical equilibrium analysis and reaction kinetics.
jumbogala
At 300 K, kp = 1.5 x 1018 for the reaction 3NO --> N2O + NO2
If 0.030 mol of NO were placed in a 1.00 L vessel and and equilibrium was established, find the equilibrium concentrations of NO, N2O and NO2.
First, I converted kp to kc using the formula kc = kp (RT)(change in mols of gas)
I get kc = (1.5 x 10^18)((0.0821)(300K))^(-1) = 6.08 x 10^16
Then, using an ICE chart, I found the mass action expression is equal to:
x2 / (0.030 - 3x)3
kc should be equal to the mass action expression.
But I can't figure out how to solve for x. There don't seem to be any simplifications I can make.
Looks to me like equilibrium is shifted faaaar to the right. What does it tell you about amount of products?
That the amount of products is very big compared to the amount of reactants. The reaction goes pretty much to completion.
So, I shouldn't even do an ICE chart, I should just use stoich?
At what point is kc big enough that I can assume the reaction goes to completion?
  • · Replies 19 ·
10K
