Find the General expression for the adiabatic relationship....
The discussion focuses on deriving the general expression for the adiabatic relationship between pressure (P) and volume (V) for any gas, starting from the ideal gas adiabatic equation: P_I(V_i)^γ = P_f(V_f)^γ, where γ = C_p/C_v. The process involves applying Maxwell relations and manipulating partial derivatives, specifically (∂P/∂V)_s and (∂V/∂T)_s, to arrive at the desired expression. The discussion emphasizes the importance of correctly applying the permuter and Maxwell relations to navigate through the derivation steps effectively.
  • Understanding of ideal gas laws and adiabatic processes
  • Familiarity with Maxwell relations in thermodynamics
  • Knowledge of partial derivatives and their applications in thermodynamic equations
  • Concept of heat capacity ratios (C_p and C_v)
  • Study the derivation of Maxwell relations in thermodynamics
  • Learn about the implications of the heat capacity ratio (γ) in various gas processes
  • Explore the application of partial derivatives in thermodynamic equations
  • Investigate the relationship between temperature, volume, and pressure in adiabatic processes
Students and professionals in physics and engineering, particularly those focusing on thermodynamics and fluid mechanics, will benefit from this discussion as it provides insights into deriving fundamental relationships in gas behavior under adiabatic conditions.
grandpa2390
edit: I figured out my mistake
Here's the entire problem. But I don't yet need help with all the steps. I'm getting off on the wrong foot (as usual)a We have shown in class that ideal gas adiabats have the form: ##P_I(V_i)^γ = P_f(V_f)^γ## with the heat capacity ratio: ##γ = \frac{C_p}{C_v}## This problem is designed to find the general expression for the adiabatic relationship between P and V for any gas.
i. The adiabatic relationship between P and V begins with the completely general form: ##(\frac{∂P}{∂V})_s##
ii. Apply the permuter to this expression.
iii.Find two Maxwell relations to replace the resulting partial derivative expressions (you will need the inverter for one of them)
iv. Insert the expression we derived in class for the adiabatic relationship between V and T for one of the partials.
v. Use the permuter on the other partial derivative that came from step iii.
v. You should at this point be able to use the relationship: https://www.physicsforums.com/file://localhost/Users/simon/Library/Group%20Containers/UBF8T346G9.Office/msoclip1/01/clip_image008.png
vi. Use another Maxwell relation on the remaining partial derivative term from step v.
vii. Apply the permuter (in reverse) to the two partial derivatives to finally arrive at the general expression of the adiabatic relationship between P and V for any gas: https://www.physicsforums.com/file://localhost/Users/simon/Library/Group%20Containers/UBF8T346G9.Office/msoclip1/01/clip_image010.png
b. Show for the ideal gas that this equation integrates to the proper expression. (before integrating, I suggest you manipulate the result of https://www.physicsforums.com/file://localhost/Users/simon/Library/Group%20Containers/UBF8T346G9.Office/msoclip1/01/clip_image012.png into a form in terms of P and V only.)
Maxwell Relations
ii. so first I applied the permuter to ##(\frac{∂P}{∂V})_s##
I got ##(\frac{∂P}{∂S})_v(\frac{∂S}{∂V})_P##
iii. The adiabatic relationship derived in class between V and T is ##(\frac{∂V}{∂T})_s = \frac{-C_v}{\frac{RT}{V}}##
so I inverted the partial of P with respect to S and used the maxwell relation on it to get ##-\frac{∂V}{∂T}## and plugged in the adiabatic relationship. I used the maxwell relation on the partial of S with respect to V to get the partial of P with respect to T.
this is about where I get lost because after I use the maxwell relation and use the permuter I can't plug in the relationship:
##(\frac{∂S}{∂T})_p = \frac{C_p}{T}##
because I don't get a partial of S with respect to T.
I get the partial of P with respect to V (constant T) times the partial of V with respect to T (constant P)
I'm going to keep playing with it.
I may have it
  • · Replies 19 ·
