Find the Hypotenuse of a Red Triangle - Urgent Help Needed
The discussion revolves around finding the hypotenuse of a triangle, which is described as red in the context of a diagram. Participants are trying to clarify the nature of the triangle and its dimensions, with references to a 3-4-5 triangle and the Pythagorean theorem.
  • Mixed
  • Some participants mention using the Pythagorean theorem to find the hypotenuse, while others question whether the triangle is indeed a right triangle or if it is misidentified as a trapezoid. There are also discussions about the clarity of the diagram and assumptions regarding the dimensions of the triangle.
The discussion is ongoing, with various interpretations being explored. Some participants have offered guidance on using the Pythagorean theorem, while others express uncertainty about the diagram's accuracy and the triangle's properties. There is no explicit consensus on the nature of the triangle or the information needed to proceed.
Participants note that the diagram lacks clarity, which affects their ability to determine the correct shape and dimensions. There are also references to assumptions about angles and side lengths that are under scrutiny.
hgphtgi
Hello Guys
could you please help me to find the hypotenuse for the red triangle please.
regards
you have a 3-4-5 right triangle the hyp is bisected
with a little thought you have the answer before you
thanks jedishrfu for your reply but can you explain to me more, because i did't understand what did you mean pls.
regards
First use the Pythagorean theorem to solve for the hypotenuse of the left triangle, you will get the ratios of all the sides you need and solving for (??) will be a simple algebra problem.
There is NO red triangle. What you have in red is a trapezoid. Do you mean the triangle all the way up to the vertex of the large triangle? If so, you know that its legs have length 3 and 4 and you can find the length of the hypotenuse using the Pythagorean theorem. If you actually mean the length of the red section as shown, you will need more information. jedishrfu is assuming that the red goes half way up the small triangle but I don't see any reason to assume that.
By the way- with the lengths as given, the angle can't be exactly 40 degrees, though it is pretty close- about 38.6 degrees.
Is it possible that the large triangle isn't a right triangle?
There is nothing that I see to indicate that it has to be.
yes, good point. why mention theta=40 and not show the right angle? This is another one of those "don't trust the diagram" problems. I retract my original suggestion, I was fooled by the apparent 3-4-5 triangle.
the angle i assumed it, not real value. Got it? please help guy
tnx
tnx
if you're saying its a rt triangle then you have the answer from my original post
Not unless you know how far up the little triangle the red goes.
hgphtgi said:
Hello Guys
regards
Here's that image displayed directly:
There's a red trapezoid, but as HallsofIvy said, there's no red triangle !
I feel like the diagram doesn't have nearly enough clarity to answer this question.
Are the sides of the quadralateral in the bottom right of the triangle perpindicular to the sides of the triangle, or is the quad a parallelgram?
yes Villyer , the quadrilateral is perpendicular to the sides of the triangle.
Tq
  • · Replies 17 ·
