Find the Number of Triangles
  • Context: Undergrad
  • Thread starter Thread starter bob012345
The discussion revolves around finding the number of triangles in a complex geometric figure using methods other than brute force counting. Participants explore various approaches, including combinatorial reasoning, symmetry, and algorithmic counting, while addressing the challenges and nuances involved in accurately determining the count of triangles.
  • Some participants suggest using a matrix to represent connections between vertices and applying an algorithm to count triangles, though this is seen as a form of brute force counting.
  • Others propose a combinatorial approach, noting that every three intersecting lines can form a triangle and discussing the implications of parallel lines on triangle formation.
  • Several participants mention the use of symmetry to simplify counting, though some express concerns about missing certain triangles due to this method.
  • There are discussions about the necessity of subtracting singular triangles, where vertices overlap, from the total count.
  • Some participants express skepticism about the effectiveness of non-brute force methods, arguing that they may complicate the problem unnecessarily.
  • There is a mention of the importance of ensuring all intersections are included in the figure for the alternative solutions to be valid.
  • Questions arise regarding the validity of counting intersections that fall outside the defined figure area as potential triangle vertices.
Participants do not reach a consensus on the best method for counting triangles, with multiple competing views on the effectiveness of brute force counting versus combinatorial and symmetry-based approaches. The discussion remains unresolved regarding the implications of including or excluding certain intersections.
Some methods proposed depend on specific assumptions about the figure's geometry, such as the presence of all intersections and the treatment of parallel lines. There are also unresolved mathematical steps related to the counting algorithms and the implications of overlapping vertices.
bob012345
TL;DR
Find the number of triangles in this busy figure.
The game is to find the number of triangles in this complicated figure by other than brute force counting and explain your method.
Mathematics news on Phys.org
I'd start with marking the vertices, e.g.,
Then, I'd make a 25x25 matrix with 1s for each pair of vertices connected by straight line, e.g., (1,2), (1,5), (1,13), ..., (2,5), (2,13), ... .
Then, I'd run a counting algorithm like this:
for i=1 to 25
.......for j=1 to 25
..............if M(i,j)=1 then
.......................for k=j+1 to 25
..................................if M(i,k)=1 then
...........................................if M(j,k)=1 then count+1
At the end, I'd divide the count by 6.
There should be a better way, because I didn't use any symmetries of this specific figure.
I would consider that to be automating a "brute force counting" method. IMO, although it is not what the OP asked for, it is still an essential step to verify the answer from an analytical method.
It can be approached as a combinatorics problem.
Mark the lines, e.g.,
Every three lines that intersect, make a triangle.
There are 12 lines. Line 1 intersects 10 other lines (not 11 other lines because there is one line parallel to it.) After the second line is selected, there are 9 or 8 possible third lines (all but the lines 3, 6, 8, and 10 have parallel lines). These combinations give the number of triangles with one of the sides being line 1. We can remove line 1 now.
There are 11 lines now to pick from, 2 to 12. And so on.
Using symmetry:
8 triangles per half-quadrant times 8?
Lnewqban said:
Using symmetry:
I think that misses a triangle 1-24-20, for example, IIUC (see image in #2 above.)
Ok. You can figure the upper bound of total possible triangles and go down from there.
And 1-7-24 as well.
We need to subtract the "singular" triangles, i.e., "triangles" with their three vertices overlapping. This happens in the vertices 7, 12, 19, 18, 17, 13, 5, 3, and 6 (I refer to the image in the #2 above.)
You have caused me to see there are 8 less than I thought. Thanks!
I think that even brute force counting would be challenging. And being confident that a mathematical method works would be very hard unless the correct answer is known (probably from some trusted brute force counting.)
There are 12 ordered pairs of "internal" lines like these:
For each, there are 10 possible choices of a third line. Total: 12*10 triangles.
There are 48 ordered pairs of non-parallel "external" lines like these:
For each, there are 8 possible choices of a non-parallel third line. Total: 48*8 triangles.
There are 32 "mixed" pairs like these:
For each, there are 9 possible choices of a non-parallel third line. Total: 32*9 triangles.
Add up, divide by 6, subtract as per post #9.
I can solve the problem by using a combination of brute force counting and symmetry.
There are 17 different triangles, which I have calculated by using brute force counting. (See Figures 1 and 2.)
Figure 1
Figure 2
Among them, 15 triangles repeat 8 times and 2 triangles repeat 4 times because of symmetry. The final result is 15×8+2×4=128.
Figure 1
Figure 2
Don’t forget these;
Here are my results;
Assuming I haven’t made a mistake which is entirely possible..
Take the 12 lines by groups of three which give 220 theoretical triples which are contenders for triangles. There are four groups of parallel lines which when combined with the other lines yield 40 triplets to remove since a triangle cannot have two parallel sides. There are 8 cases internal to the figure where three lines cross at one point which cannot form a triangle. There are 8 points which also have three lines meeting at a point. Lastly, the center vertex has four lines crossing which taken 3 at a time eliminate another 4 triples. So we have 220-40-16-4=160.
I also count 18 with eight-fold symmetry and 4 with four-fold symmetry yielding a total of 160 triangles.
That seems logical. This is a treacherous problem. I would feel more confident of your logic if there was a simple, brute-force, counting that gave the same answer, but everything I think of quickly gets complicated.
I wrote a program to do brute force counting and its answer matches that of @bob012345 in post #15.
I have not thoroughly examined the results, but I have some realistic hope that my program is correct.
Here is the program and results. Each triangle is identified by three vertices numbered as in @Hill Post #2.
Perl:
# for brute force counting of triangles in the diagram here:
#   https://www.physicsforums.com/threads/find-the-number-of-triangles.1083666/
# Define each line by the vertices on it. Starting at top, first line and proceeding clockwise. Use the vertex numbers in post #2.
# Define labels to match the diagram in post #2 because some lines going clockwise are skipped and it's hard to keep track of.
# The top-center vertex is 9 and its lines are 9A, 9B, 9C. Other lines are identified similarly
$l[0]= " 9 4 3 5 14 15 ";  $id[0]="9A";
$l[1]= " 9 7 6 17 24 ";  $id[1]="9B";
$l[2]= " 9 10 12 19 22 25 ";  $id[2]="9C";
$l[3] = " 11 10 7 3 2 8 ";  $id[3]="11A";
$l[4]= " 11 12 6 13 15 ";  $id[4]="11B";
$l[5]= " 11 20 19 18 23 24 ";  $id[5]="11C";
$l[6]= " 21 20 12 7 4 1 ";  $id[6]="21A";
$l[7]= " 21 19 6 5 8 ";  $id[7]="21B";
$l[8]= " 21 22 18 17 16 15 ";  $id[8]="21C";
# skip first line out of 25. already done.
$l[9]= " 25 18 6 3 1 ";  $id[9]="25B";
$l[10]= " 25 23 17 13 14 8 ";  $id[10]="25C";
# skip first 2 lines out of 24. already done.
$l[11]= " 24 16 13 5 2 1 ";  $id[11]="24C";
# all the rest are done
# **********  Begin main algorithm  *******************
# loop through all combinations of 3 distince lines and look for intersections
foreach $i (0..9){
   foreach $j (($i+1)..10){
# ******  Define a subroutine to check for vertex intersection between two lines  ***************
sub findIntersection {
      my( $firstLine )= shift @_;
      my( $secondLine )= shift @_;
      # Each vertex in the local string, $li, will be deleted as it is looked for in the other line
      my( $li ) = $l[$firstLine];
      while( $li =~ s/(\d+)// && ! $Intersection ){
         $Vertex = $1;
         if( $l[$secondLine] =~ / $Vertex / ){
            return $Vertex; # return the vertex of the intersection
   return 0;  # Return 0 indicating no intersection vertex
# *******  Continue with main program  **********************
      $ijIntersection = &findIntersection($i, $j);
      # If the first two lines don't intersect, skip to next pair
      if( $ijIntersection == 0 ){next}
      # Get intersections of first i&j lines with k line
      foreach $k (($j+1)..11){
         $ikIntersection = &findIntersection($i, $k);
         $jkIntersection = &findIntersection( $j, $k);
         # If any intersection is zero, no triangle with those 3 lines
         if( $ikIntersection == 0 || $jkIntersection == 0 ){next}
         # If all 3 intersections are different and nonzero, it is a triangle
         if(
             $ijIntersection != $ikIntersection
             && $ijIntersection != $jkIntersection
             && $ikIntersection != $jkIntersection
            # Triangle found. Store in array @triangles
            $numTriangles++;
            push( @triangles, "$ijIntersection, $ikIntersection, $jkIntersection");
print "There are $numTriangles triangles:\n";
# Sort triangles and print
foreach $triangle (sort @triangles) {
   print "$triangle\n";
Here are the results:
There are 160 triangles:
10, 12, 11
10, 12, 7
10, 19, 11
10, 19, 8
10, 25, 3
10, 25, 8
11, 12, 20
11, 13, 23
11, 13, 24
11, 15, 18
11, 2, 13
11, 2, 24
11, 3, 18
11, 3, 6
11, 6, 18
11, 6, 19
11, 7, 12
11, 7, 20
11, 8, 13
11, 8, 19
11, 8, 23
11, 8, 6
12, 13, 1
12, 15, 21
12, 19, 11
12, 19, 21
12, 19, 6
12, 22, 15
12, 22, 21
12, 25, 1
12, 25, 13
12, 25, 6
12, 6, 1
12, 6, 21
14, 5, 13
15, 13, 16
15, 13, 17
15, 14, 13
15, 14, 17
15, 3, 18
15, 3, 6
15, 4, 12
15, 5, 13
15, 5, 16
15, 5, 6
15, 6, 18
17, 16, 13
17, 24, 13
17, 24, 16
17, 6, 18
18, 16, 1
18, 17, 25
18, 23, 17
18, 23, 25
18, 24, 1
18, 24, 16
19, 12, 20
19, 18, 21
19, 18, 6
19, 22, 18
19, 22, 21
19, 23, 8
19, 24, 5
19, 25, 18
19, 25, 23
19, 25, 6
19, 25, 8
20, 18, 1
20, 18, 21
20, 19, 21
20, 24, 1
21, 1, 16
21, 1, 18
21, 1, 5
21, 1, 6
21, 5, 16
21, 6, 18
21, 8, 17
22, 25, 17
22, 25, 18
23, 24, 13
24, 17, 18
24, 17, 23
24, 6, 18
24, 6, 19
24, 7, 20
25, 1, 13
3, 14, 25
3, 14, 8
3, 15, 11
3, 2, 1
3, 4, 7
3, 5, 1
3, 5, 2
3, 5, 8
3, 8, 25
4, 15, 21
4, 3, 1
4, 5, 1
4, 5, 21
5, 14, 8
5, 15, 21
5, 3, 6
6, 13, 1
6, 13, 25
6, 13, 5
6, 13, 8
6, 15, 21
6, 17, 13
6, 17, 15
6, 17, 21
6, 17, 25
6, 17, 8
6, 24, 1
6, 24, 11
6, 24, 13
6, 24, 5
6, 5, 1
6, 7, 12
6, 8, 25
7, 17, 21
7, 17, 8
7, 2, 1
7, 24, 1
7, 24, 11
7, 24, 2
7, 3, 1
7, 6, 1
7, 6, 11
7, 6, 21
7, 6, 3
7, 6, 8
7, 8, 21
8, 2, 13
8, 2, 5
8, 3, 6
8, 5, 13
9, 14, 17
9, 14, 25
9, 15, 12
9, 15, 17
9, 15, 22
9, 15, 6
9, 17, 22
9, 17, 25
9, 24, 19
9, 3, 10
9, 3, 25
9, 3, 6
9, 3, 7
9, 4, 12
9, 4, 7
9, 5, 19
9, 5, 24
9, 5, 6
9, 6, 12
9, 6, 19
9, 6, 25
9, 7, 10
9, 7, 12
IMHO, the desire for a non-"brute force counting" method is misguided here. The logic is so specialized and convoluted that it required several erroneous tries to create a "Rube Goldberg" logic that might work. The "brute force" method still requires some tricks, but the result is much more flexible and easy to follow.
I enjoyed thinking about it. Just for fun of finding an alternative approach.
  • Agree
It occurred to me that the alternative solution depends on the fact that all intersections are included in the figure. It happened to be so in this case, but it needs to be checked for the solution to be correct.
I'm not sure what you mean here.
1) If an intersection is beyond the figure area, should it count as a possible triangle vertex or not?
2) Which solution are you calling the "alternative solution"?
I think that’s correct. I was thinking along those lines too as I tried to apply the logical method to this figure;
I can get the right number as long as I remove all triplets that have a vertex outside the figure.
  • Agree
I think the intent is that it would not count. Only vertices in the original figure count.
  • Agree
2) The solution based on counting triads of intersecting lines.
1) E.g.,
if the figure doesn't include two triangles that I've erased, then they don't count.
1) E.g.,
It certainly complicates symmetry arguments.
Maybe I misunderstand your first statement. I don't see that it invalidates anything about a triads of intersecting lines. Triangles still have 3 distinct sides.
The first statement answered the question,
Sure, but not every three non-parallel lines necessarily make a triangle in a given figure.
Perhaps so. I have yet to make a simple regular hexagon work but one can see the answer by inspection!
I see. The solutions that depend on counting combinations of 3 lines don't work. That and the need for symmetry is key to most of the ideas here. The solutions are not very "robust". I have a general preference for robust approaches, but they are often not elegant.
  • Agree
bob012345 said:
TL;DR: Find the number of triangles in this busy figure.
brute force counting and then work backwards
knowing the answer seems to nearly always lead to a clearer path
ps. It will be at least another week before I can count all these stinking triangles by brute force, so it will be at least 6 months before I come up with a method.
  • Haha
The answer is 160. I'm also looking for a way backwards.
  • Love
  • · Replies 20 ·
