Find the rotational inertia of a sphere suspended from the ceiling
The discussion focuses on calculating the rotational inertia of a solid uniform sphere and an array of point masses attached to a rod. The rotational inertia of the sphere about its diameter is established as (2/5)MR², while its inertia about the point of attachment at the ceiling is correctly derived as 47/5MR² using the parallel axis theorem. For the array of three identical masses on a rod, the correct rotational inertia about one end is confirmed as 5/4mL². Participants emphasize the importance of accurately applying the parallel axis theorem and drawing diagrams for clarity.
  • Understanding of rotational inertia and its formulas
  • Familiarity with the parallel axis theorem
  • Basic knowledge of geometry related to spheres and rods
  • Ability to interpret and create diagrams for physical problems
  • Study the application of the parallel axis theorem in various scenarios
  • Learn about the derivation of rotational inertia for different shapes, including cylinders and disks
  • Practice problems involving multiple masses and their combined rotational inertia
  • Explore advanced topics in rotational dynamics, such as torque and angular momentum
Students studying physics, particularly those focusing on mechanics and rotational dynamics, as well as educators seeking to enhance their teaching methods in these topics.
grouchy
A solid uniform sphere of radius R and mass M has a rotational inertia about a diameter that is given by (2/5)MR2. A light string of length 2R is attached to the surface and used to suspend the sphere from the ceiling. Its rotational inertia about the point of attachment at the ceiling is
- 47/5mR^2 (not sure how to find it)
Three identical objects, each of mass M, are fastened to a massless rod of length L as shown. The rotational inertia about one end of the rod of this array is
-5/4mL^2
- again no clue how to get this
Consider the parallel axis theorem.
I looked at that stuff but I don't see how to use to solve these problems.
For the second one I kinda guessed and got it but I don't think its the right way.
I used 1/12ml^2 for the center mass and 1/3ml^2 for the far right mass and added it together. then since there are 3 masses I multiplied by 3 and for 5/4mL^2 but I don't think that's how i"m supposed to find it.
Look at it again. For the first problem, you have the rotational inertia about the center of mass but you need it about the point of attachment. Sounds like a perfect opportunity to use the parallel axis theorem!
For the second problem, please attach a diagram.
Another perfect opportunity to apply the parallel axis theorem. Alternatively: What's the rotational inertia of a point mass M at a distance D from an axis?
well for the first one I tried
2/5mr^2 + mL^2
2/5mr^2 + 2mL^2 and got 12/5mr^2 which is wrong...honestly I got no clue how this parallel axis thereom stuff works, if u got any tips I'd appreciate it.
2/5mr^2 + mL^2
OK, what did you use for "L"? That should be the distance between the center of mass to the point of attachment (in terms of R, of course). (Draw yourself a diagram, unless one is provided--in which case, attach it.)
I used 2R for L since that's how long it says the string is, and no diagram with the problem :(
Careful: The problem says "A light string of length 2R is attached to the surface"
Draw your own diagram! (Just for yourself.)
I just don't see it...I drew the diagram, but I don't see what I'm trying to find...
Your diagram should show a sphere hanging from a string attached to the ceiling. The string is length 2R and attaches to the surface of the sphere. Where's the center of the sphere?
the center would be another distance R. so
2/5mr^2 + 3mL^2 = 17/5mr^2 which is still wrong :(
ah, since the length is 3R it would be M(3R)^2 so it would be 9MR^2 so..
2/5mr^2 + 9mr^2 = 47/5mr^2 would that be the proper way to do it?
For the second one...since it is rotating on the far left mass, I can disregard it since the inertia would be of the masses rotating around it right? So...
the middle mass mr^2 = m(L/2)^2 = 1/4mL^2
the far right mass mr^2 where r would be the length to the point of rotation so mL^2
1/4mL^2 + mL^2 = 5/4mL^2
I think I did the two problems the correct way, if there is anything you see shady about my method I'd love to know. THX for your patience and help lol. I think I'm starting to understand this some. Thx again! Peace.
Your latest solutions to both problems are perfectly correct. Well done!
14K
