MHB Find Triplets to Satisfy $x+y+z+xy+yz+zx=xyz+1$
  • Thread starter Thread starter anemone
The discussion centers around finding all triplets of positive integers (x, y, z) that satisfy the equation x+y+z+xy+yz+zx=xyz+1, with the condition x ≤ y ≤ z. It is established that if x is greater than or equal to 4, no solutions exist due to the inequality derived from the equation. For x equal to 2, the solutions (y, z) are found to be (3, 13) and (5, 8), while for x equal to 3, the only solution is (3, 7). The confirmed solutions are (2, 3, 13), (2, 5, 8), and (3, 3, 7). The discussion concludes with acknowledgment of contributions from participants.
anemone
MHB
POTW Director
Determine all triplets $(x,\;y,\:z)$ of positive integers such that $x \le y \le z$ and
$x+y+z+xy+yz+zx=xyz+1$.
Mathematics news on Phys.org
Hello.
(x+1)(y+1)(z+1)=2(1+xyz)
At a glance:
(1,0,0) \ (0,1,0) \ (0,0,1) \ (-1,-1,-1)
Only meets the two restrictions: (1,0,0)
Regards.
The above solution is not correct. The question asks for positive integers, and $0$ IS NOT POSITIVE!
$$2,4,13$$
$$2,5,8$$
$$3,3,7$$
mente oscura said:
Hello.
At a glance:
Regards.
Thanks for participating, mente oscura! But your answer isn't correct. I'm sorry.:(
$$2,4,13$$
$$2,5,8$$
$$3,3,7$$
Yes, those three are the only solutions but if you don't mind me asking, I would like to see how you approached the problem, sounds good to you?
[sp]If $x$ (the smallest of these numbers) is $\geqslant4$ then each of $x,y,z$ is $\leqslant\frac14yz$; and each of $xy,xz,yz$ is $\leqslant yz$. Therefore $x+y+z+xy+yz+zx \leqslant \frac{15}4yz$. But $xyz + 1>4yz > \frac{15}4yz$. So there cannot be any soluions with $x\geqslant4.$
If $x=2$ then the equation becomes $2yz+1 = yz + 3(y+z) + 2$, so that $yz - 3(y+z) = 1$, or $(y-3)(z-3) = 10$. The only positive integer solutions with $y\leqslant z$ are $(y-3,z-3) = (1,10)$ or $(2,5)$, giving $(y,z) = (3,13)$ or $(5,8).$
If $x=3$ then the equation becomes $3yz+1 = yz + 4(y+z) + 3$, so that $yz - 2(y+z) = 1$, or $(y-2)(z-2) = 5$. The only solution is $(y-2,z-2) = (1,5)$, giving $(y,z) = (3,7)$.
Thus the only solutions are those given by eddybob:$(x,y,z) = (2,3,13),\ (2,5,8),\ (3,3,7)$.[/sp]
Thank you Opalg for participating and also your well explained solution!
Solution provided by other:
Let $x-1=p$, $y-1=q$ and $z-1=r$, the equation may be written in the form $pqr=2(p+q+r)+4$, where $p,q,r$ are integers such that $r \ge q \ge p \ge 0$. Observe that $p=0$ is not possible, for then $0=2(p+q)+4$ which is impossible in non-negative integers. Thus we may write this in the form
$2 \left( \dfrac{1}{pq}+\dfrac{1}{qr}+\dfrac{1}{rp} \right) +\dfrac{4}{pqr}=1$.
If $p \ge 3$, then $q \ge 3$ and $r \ge 3$. Then left side is bounded by $\dfrac{6}{9}+\dfrac{4}{27}$ which is less than 1.
We conclude that $p=1$ or $p=2$.
Case I:
Suppose $p=1$. Then we have $qr=2(q+r)+6$ or $(q-2)(r-2)=10$. This gives $q-2=1, r-2=10$ or $q-2=2$ and $r-2=4$ (recall $r \ge q$). This implies $(p,q,r)=(1,3,12), (1,4,7)$
Case II:
If $p=2$, the equation reduces to $2qr=2(2+q+r)+4$ or $qr=q+r+4$. This reduces to $(q-1)(r-1)=5$. Hence $q-1=1$ and $r-1=5$ is the only solution. This yields $(p,q,r)=(2,2,6)$
Reverting back to $x, y, z$ we get three triplets $(x,y,z)=(2,4,13),(2,5,8),(3,3,7)$.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
