Find wave speed by using relation x-y at given time.
19 replies · 7K views · last reply
NihalSh
The displacement due to a wave moving in the positive x-direction is given by ##y=\frac{1}{1+x^2}## at time t=0 s and by ##y=\frac{1}{1+(x-1)^2}## at t=2 s, where x and y are in meters. Find the velocity of the wave in m/s.
## \frac{∂^2y}{(∂x)^2}=\frac{1}{v^2}.\frac{∂^2y}{(∂t)^2}##
Since we have to deal with partial derivative wrt x on L.H.S., we can simply take the derivative of given x-y relations.
For case, t=0 we have:
or ##y.(1+x^2)=1##
differentiating on both sides wrt x, we get
##(1+x^2).\frac{∂y}{∂x}=-2.x.y##
differentiating again and substituting value of y, we get
## \frac{∂^2y}{(∂x)^2}=\frac{2.(3.x^2-1)}{(1+x^2)^3}##
Similarly for case t=2, we get:
## \frac{∂^2y}{(∂x)^2}=\frac{2.(3.(x-1)^2-1)}{(1+(x-1)^2)^3}##
The only common factor they seem to have is 2 so that must be equal to ##\frac{1}{v^2}##.
##\frac{1}{v^2}=2##
that means ##v= \sqrt{\frac{1}{2}} m/s≈0.71 m/s##
But my book says the answer is ##v=0.5 m/s##, I haven't got a clue what went wrong or how to approach it with some other method.
Any help would be greatly appreciated, thanks.
Hi NihalSh!
##\frac{1}{v^2}=2##
I can't follow this.
Anyways, you have a notation problem in your equation. ##\frac{∂^2y}{(∂x)^2}## is not same as ##\frac{∂^2y}{∂x^2}## and I think this is what you mean.
To solve the problem, you need to find ##y(x,t)##. Find the partial derivatives and substitute in the linear wave equation to find v.
from my point of view (as explained in the textbook), the velocity in a given material doesn't change with time unless something physical is being changed like tension. so I compared the partial derivative with the equation mentioned :
## \frac{∂^2y}{∂x^2}=\frac{1}{v^2}.\frac{∂^2y}{∂t^2}##
this part ,##\frac{∂^2y}{∂t^2}## will change in both cases but the factor ##\frac{1}{v^2}## remains the same and it should be constant. so I did equated the constant factor with ##\frac{1}{v^2}##
##\frac{∂}{∂x}.\frac{∂y}{∂x}= \frac{∂^2y}{(∂x)^2} =\frac{∂^2y}{∂x^2}##
I think it makes no difference, I used a rather unconventional notation but both are correct I believe. I'll be careful next time
I have no clue how to proceed, the wave could have any shape since its not mentioned that it's a sinusoidal function. Please show how to proceed further.
I am still not able to understand.
You need to find ##y(x,t)## which satisfies the given conditions. Do you see it has to be of the following form:
$$y(x,t)=\frac{1}{1+(x-kt)^2}$$
Look for an appropriate value of k (where k is some constant) and find the partial derivatives.
I'll give your method a try and then post the results.
Edit : I gave it a try, but it is turning out to be to complex. The question was a MCQ. This is as far as I could get.
if I assume the wave has equation of the form,
##y(x,t)=\frac{1}{1+(x-kt)^2}## here k should be 1/2 by trial and error.
$$\frac{∂^2y}{∂x^2}=\frac{2.(3.(x-kt)^2-1)}{(1+(x-kt)^2)^3}$$
$$\frac{∂^2y}{∂t^2}=\frac{2.((x-kt)^2-1)}{(1+(x-kt)^2)^2}$$
if I proceed further by taking ##k=\frac{1}{2}##, then
##4v^2=\frac{x^4-1}{3x^2-1}## for t=0
##4v^2=\frac{(x-1)^4-1}{3(x-1)^2-1}## for t=2
But ##v## should be constant, right?...but here it is a function of x. Did I do something wrong?...or did I miss something crucial?...or maybe this isn't the way?!?:confused:
Doesn't look right to me.
No, that's not right. Don't substitute the values, you have to substitute the expressions for derivatives directly into the linear wave equation. t=0 and t=2 were given in the problem statement so that you can deduce ##y(x,t)##.
Hi NihalSh :smile:
You are putting way too much effort than is actually required .
I will try and help you out.
Do you understand that wave equation is a function of both x and t and not x alone i.e y=f(x,t) .
First try and express y as a function of x and t i.e y=f(x,t) .A little hit and trial will be okay , no calculus required .
Let me know what you get.
Tanya Sharma said:
First try and express y as a function of x and t i.e y=f(x,t) .A little hit and trial will be okay , no calculus required :wink:.
Sounds interesting, I am curious as to how you would do that without calculus.
I appreciate your help but I haven't got a clue where I am being led!:-p
It doesn't seem reasonable.
Tanya Sharma said:
Hi NihalSh :smile:
I know, right! This question is an MCQ for god's sake. But I've managed to figure it out, thanks to Walter Lewin. I'll post the solution in a minute for anyone's future reference.
:smile: .I think Nihal has figured it out.
You don't need any derivatives. Anyway you don't have y as a function of t so you cannot calculate derivatives in respect to t.
If you take an arbitrary point at distance x1, the displacement at t=0 is y1=1/(1+x1^2)
At t=2, a point with the same displacement, y1, will have to be at a distance x1+1.
So in 2 seconds the point with the same displacement moves by 1 unit.
The wave speed is then...
I can now guarantee you since I have figured it out, it can be done without trial and error and without calculus. There is an appropriate way.
If you want to change a function (ex. ##y=x^2 +1##) to traveling/moving function. Then all we have to do is replace ##x→x-vt##, where ##v## is the velocity and ##t## is the time.
Since I have been given two value of ##y##, first at t=0. This value is simply the function which I want to convert to traveling function. So replacing ##x→x-vt##, in the given t=0 case.
I get ##y=\frac{1}{1+(x-vt)^2}##, then comparing with the second case I simply get:
##x-vt=x-1## here t=2, so
##v=+\frac{1}{2}##
+sign indicates the function travels in the +ve ##x## direction.
P.S. : Source
first 2-3 minutes of the video explains the method.
thanks to everyone for helping out!
I know the solution looks messy, but it is very very easy.
:thumbs:
Just check if you can apply the same technique if y=1/[1+(1-x)2] at t=2 instead of what is given in the original question.
Tanya Sharma said:
:thumbs:
Just check if you can apply the same technique if ##y=\frac{1}{1+(1-x)^2}## at t=2 instead of what is given in the original question.
for the technique to apply we should know what ##y## is at t=0. Otherwise, it becomes trial and error.
since ##(1-x)^2## is essentially same as ##(x-1)^2## so it should be same for ##y=\frac{1}{1+(1-x)^2}## and ##y=\frac{1}{1+(x-1)^2}##
assuming ##y=\frac{1}{1+x^2}## at t=0, then it simply follows replace ##x→x-vt##.
the answer would still come out to be ##v=+\frac{1}{2}##
Edit: Alternate method:
##y=\frac{1}{1+x^2}=\frac{1}{1+(-x)^2}## at t=0 and ##y=\frac{1}{1+(1-x)^2}## at t=2
##x→x-vt##
##-x→vt-x##
Solving gives same answer, that is ##v=+\frac{1}{2}##
Similar questions I found in other textbooks can also be solved by this method:
The displacement function of a wave traveling along positive x-direction is ##y=\frac{1}{2+3x^2}## at t=0 s and by ##y=\frac{1}{2+3(x-2)^2}## at t=2 s, where y and x are in meters. Find the velocity of the wave.
Answer: +1 m/s
If at t=0 s, a traveling wave pulse on a string is described by the function ##y=\frac{6}{x^2+3}##. What will be the wave function representing the pulse at time t, if the pulse is propagating along positive x-axis with speed 4 m/s?
Answer: ##y=\frac{6}{(x-4t)^2+3}##
At t=0 s, a transverse wave pulse in wire is described by the function ##y=\frac{6}{x^2+3}## where x and y are in meters. Write the function y(x,t) that describes this wave if it is traveling in the positive x-direction with a speed of 4.50 m/s.
Answer: ##y(x,t)=\frac{6}{(x-4.50t)^2+3}##
P.S. : It works like a charm every time because as I found out it is among the very basic equations normally using to derive wave equations from oscillations/wave pulse.
Excellent :smile:
What about y(x,t=0) = 1/(1+x3) and y(x,t=2) = 1/(1+(1-x)3) ?
Tanya Sharma said:
Excellent :smile:
What about ##y(x,t=0) = \frac{1}{1+x^3}## and ##y(x,t=2) = \frac{1}{1+(1-x)^3}## ?
They couldn't be of the same wave function. I believe they both are part of different wave functions. Hence, my method doesn't apply.:wink:
P.S. : ##y(x,t)## function of ##y(x,t=0) = \frac{1}{1+x^3}## is
##y(x,t) = \frac{1}{1+(x-vt)^3}##
which doesn't match the second given function.
I believe you are just testing the limit of method's applicability, but I can assure it would work for every real case (unlike this one).
Sorry...that was a typo
I meant y(x,t=0) = 1/(1-x3) ,not y(x,t=0) = 1/(1+x3) .
I am not testing the method.Just trying to understand this technique by applying different functions.
##x→x-vt##
##y(x,t)## function of ##y(x,t=0) = \frac{1}{1-x^3}## is
##y(x,t) = \frac{1}{1-(x-vt)^3}##
since ##y(x,t=2) = \frac{1}{1+(1-x)^3}=\frac{1}{1-(x-1)^3}##
solving them would give ##v=+\frac{1}{2}##
