Find zeros of quadratic equation
To find the zeros of the quadratic equation P(x) = 4(x+7)² + (x+7) - 3, a substitution is made where u = x + 7, transforming the equation into f(u) = 4u² + u - 3. After factoring this quadratic equation, the next step involves solving for u, which leads to specific values. Once the values for u are determined, back substitution is necessary to find x using the equation x = u - 7. This method effectively allows for the calculation of the zeros of the original quadratic equation.
Torshi
Find the zeros of the quadratic equation?
P(x)=4(x+7)^2+(x+7)-3
I substituted and made it 4u^2+u-3 ?? Then after that I factor then back substitute?? I'm not sure how to back substitute tho.
Think about what u is equal to when you make the substitution. If you have that and the value for u, finding x should be straightforward.
What's the equation for u in terms of x? Once you have this, solve for x in the equation and plug in the values you got for u.
You did a change of variables. You substituted u for x where u = x+7 to get the equation
f(u) \, = \, 4u^{2} \, + \, u \, - \, 3 \, = \, 0
solve for u in the above expression then use u = x + 7 to find x for each u.
i.e. since u = x+7 then x = u - 7 gives you x.
