Finding a, b, c from inflection point at origin and local maximum at (2,4)
  • Thread starter Thread starter bengalibabu
    Calculus
14 replies · 3K views
bengalibabu
Calculus help please!
The function f(x)= ax3 + bx2 + cx has a point of inflection at the origin and a local maximum at the point (2,4). Find the values of a, b and c.
I understand that the point of inflection is (0,0) and the local maximum at (2,4) but how can u find a, b & c using these values?
You need three equations for your three unkowns. The point of inflection indicates that the second derivative is zero at (0,0). The local maximum at (2,4) gives you two pieces of information which can give you equations. First of all, f(2) must be 4 in order for the graph to pass through this point. Secondly the derivative is zero at two. This gives you three equations in three unkowns, so you can solve them.
Hint:
What do f'(x) and f''(x) tell you about points of inflection, local maxima etc.?
Can you find f'(x) and f''(x) here, at the points x=0 and x=2?
so is this how it is done:
4=a(2)^3 + b2^2 + 2c
4=8a + 4b +2c
4=2(4a + 2b + c)
2=(4a + 2b + c)
0=3ax^2 + 2b^2 +c0
0=3a(4) + (4)b + c
c= -12b - 4b
6ax + 2b = 0
b=-3ax
b=0
2=(4a + 2b + c)
2=4a
a=1/2
since the inflection point is x=0 b should be 0 if your work is correct. ur second derivative is right.
im just really being hesitant on the fact that since b=0 then c must also equal 0
k nelson...if b=o then c=0 as well right according to the calculations...or is that wrong too?
yes, the calculation you may have made a minor error
0=3a(4) + (4)b + c
c= -12b - 4b
yes c would equal zero according to this statement
but i think you meant
c=-12a - 4b
