Finding a Basis for 3x3 Symmetric Matrices
13 replies · 6K views · last reply
robierob12
This is the problem that I am working on.
Find a basis for the vector space of all 3x3 symetric matricies.
Is this a good place to start
111
110
100
using that upper triangular
then spliting it into the set.
100 010 001 000 000 000
000 000 000 100 010 000
000 000 000 000 000 100
would that work?
i know that it has to be linearly independent and span.
Are any of the matrices you wrote out symmetric?
The matrix you started from isn't upper triangular, by the way. Why would you want to start with that matrix anyway? A symmetric matrix is one satisfying A=A^t, so take the 3x3 matrix
[a,b,c]
[d,e,f]
[g,h,j]
and transpose it, equate the two, what conditions do you now have on a,b,..,j?
I choose
111
110
100
because it was equal to its transpose.
I know that b is equal to to d and so on for the transpose you mention.
I choose the six randomly as a guess.
seeing what happens to the above matrix you gave me though, how about this?
100
000
000 because a doesn't move
010
100
000 those have to be there
001
000
100 same here
000
000
001 and this
000
001
010
I guess that I am just looking for a pattern. Those seem better, I feel like there should be six though.
Ok. So here is where my new issue arrises.
For this set of matricies to be a BASIS for all symertric 3x3 matricies then it has to linearly independent... right?
So I took my set.
100 010 000 001 000 000
000 100 010 000 001 000
000 000 000 100 010 001
and set it equal to a 3x3 zero matrice, and set up a system with scalars.
They end up all equaling zero... the trivial solution. Nice.
But they have to check out for span also to be considered a basis right?
That means that each one has to be a linear combination of the other five remaining right?
Well for some of them I get 0 = 1 for a solution
Anyone know where I am going wrong?
Thanks, Rob
Yes. It is this line:
Reread the definition of span. Cos you've just written something that implies linear dependence. It spans if every symmetric matrix can be written as a combination of them, and that is obviously true.
would anyone help me solve this problem?
I read all posts above but still confuse.
Much appreciate.
What is consfusing you? What is the generic symmetric matrix? Therefore what is a basis?
I know 3x3 symmetric matrix formed by
a b c
d e f
g h i
and b=d c=g f=h
but I don't know how to start on this case.
What I'd write at beginning on my homework paper?
To find a basis you just do three steps:
1) find the generic matrix (or vector in the general case)
2) break it up into a number of matricies where each one containes only one type of parameter with everything else zeros(but no two contain the same type)
3) turn the parameters in each matrix into ones.
