Finding a Cubic Polynomial with Remainders
  • Thread starter Thread starter mangren
    Cubic Polynomial
The problem involves finding a cubic polynomial that gives specific remainders when divided by two quadratic polynomials. The remainders are (5x + 4) for the first quadratic (x^2 - x + 2) and (12x - 1) for the second quadratic (x^2 + x - 1).
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the setup of the polynomial division and the implications of the remainders. Some express confusion about their attempts to express the cubic polynomial in terms of the quadratic divisors and the remainders. Others question the correctness of their division methods and seek clarification on how to combine the equations derived from the polynomial divisions.
There is ongoing exploration of the relationships between the coefficients of the polynomial and the remainders. Some participants have attempted to set up equations based on their polynomial expressions, while others are questioning their methods and seeking further guidance on how to proceed. Multiple interpretations of the problem setup are being discussed.
Participants note the complexity of the problem due to the number of unknowns involved and the requirement to equate coefficients for polynomial equality. There is a recognition that the problem may require careful handling of the polynomial division process.
mangren
A cubic polynomial gives remainders (5x + 4) and (12x -1) when divided by x^2 - x + 2 and x^2 + x - 1 respectively. Find the polynomial.
I presume that you seek help with this problem, rather than merely intending to duplicate your textbook?
Well, we can't help you effectively without knowing what you have tried and where you are stuck...
Sorry, this is the first time I posted here. I'm lost in this problem. I tried starting solving it by using:
P(x)/(x^2 - x + 2) = Q(x) + (5x + 4) and
P(x)/(x^2 + x - 1) = R(x) + (12x - 1)
but to no luck can't solve it... any suggestions?
Well, first, you haven't divided quite correctly. (e.g. 4/3 = 1 + 1/3, not 1 + 1)
You also know some information about Q and R, don't you?
Finally, do you see any way to combine those two equations to get more information?
just the basic stuff i know, but when all the x's come in, they confuse me...
i tried to make P(x) = ax^3 + bx^2 + cx + d and divide it with x^2 - x + 2 giving a remainder x(b + c) -a(x + 2) - 2b + d which is equal to (5x + 4), and then divided P(x) with the x^2 + x - 1 giving a remainder x(2a + c) - bx + d - a which is also equal to (12x - 1), then i tried to solve simultaneously, but there are just too many unknowns... don't know what to do next...
No, that's wrong. P(x)/(x^2- x+ 2)= Q(x)+ (5x+4)/(x^2- x+ 2) and
p(x)/(x^2+ x- 1)= R(x)+ (12x- 1)/(x^2+ x- 1).
It might help to write it as P(x)= Q(x)(x^2- x+ 2)+ 5x+4 and P(x)= R(x)(x^2+ x-1)+ 12x-1.
You also know that P is cubic so Q and R must be linear. P(0)= 2Q(0)+ 4= -R(0)- 1 and P(1)= 2Q(1)+ 9= R(x)+ 11. Two points should be enough to determin a linear equation.
I see four dimensions of equations and four unknowns; there shouldn't be a problem. Don't forget that, for two polynomials to be equal, their coefficients must be equal!
This method looks easy but I don't get it. Please explain further.
I tried again to solve it simultaneously resulting in 2cx + ax - 3a - 2b + 2d = 17x + 3, still far from the solution.
  • · Replies 36 ·
