Finding a Function f(x,y,z) from a Given Vector Field Using ∇ x q=0
  • Thread starter Thread starter terryfields
    Vectors
The discussion revolves around finding a function f(x,y,z) from a given vector field q, specifically addressing the condition that the curl of q is zero (∇ x q = 0). The original poster presents a vector field and seeks to determine the corresponding scalar function f such that q = ∇f.
  • Participants discuss the interpretation of ∇f as the gradient and explore how to approach the integration of the vector field components to find f. Questions arise about the necessity of integrating with respect to multiple variables and the treatment of constants during integration.
Participants are actively engaging with the problem, sharing insights about integrating the components of the vector field and the implications of treating other variables as constants. Some guidance has been offered regarding the integration process and the nature of the resulting function f.
There is an emphasis on understanding the relationship between the vector field and the scalar function, as well as the importance of ensuring that the integrated function aligns with the original vector field components. Participants are also considering how to handle constants of integration appropriately.
terryfields
consider the vector field q=yzcos(xy)i+xzcos(xy)j+(sin(xy)+2z)k
verify that x q=0 and concequently determine a function f(x,y,z) such that q=f
now i have completed the first part by using the determinant and multiplying out, it is quite obvious that the whole thing equals zero, however i don't know how to do the second part "concequently determine a function f(x,y,z) such that q=f"
my first question is does f simply mean the dot product when there is no dot there? i assume it does
and my second question is how do i approach this question? thanks
Hi terryfields! :smile:
No, f is the gradient …
for an ordinary function f(x) of a vector x, f is the gradient vector (∂f/∂x1, … ,∂f/∂xn) :smile:
And if x q = 0, then there must be an f with q = f.
(and basically you find f by integrating each component of q, and using a little common-sense for the "constants"! :wink:)
ah ok, so do i just need to integrate each term in respect to x or in respect to x,y and z?
The i term with respect to x, the j term with respect to y, and the k term with respect to z. :wink:
ok, so by my calculations i would get (zsin(xy))i+(zsin(xy))j+(zsin(xy)+z2)k i assume this is how it's writen? as i now assume i need to do ∇ x f = 0 to find my constants?
And, as tiny tim said, "using a little common-sense for the "constants"!" The reason he put "constants" in quotes is because the partial derivative with respect to one variable treats the other variables as constants- and you have to consider that in taking an "ant-derivative".
For example, if the v were the vector [itex]2xy\vec{i}+ (x^2+ z)\vec{j}+ (1+ y)\vec{k}[/itex], then you must have [itex]\partial f/\partial x= 2xy[/itex], [itex]\partial f/\partial y= x^2+ z[/itex], and [itex]\partial f/\partial z= 1+ y[/itex]. Integrating [itex]\partial f/\partial x= 2xy[/itex] gives [itex]f= x^2y+ \phi(y,z)[/itex] where [itex]\phi[/itex] can be any function of y and z since its derivative, with respect to x, is 0. If we differentiate that with respect to y, we get [itex]\partial f/\partial y= x^2+ \partial \phi/\partial y= x^2+ z[/itex] or [itex]\partial \phi/\partial y= z[/itex]. (Notice how the "[itex]x^2[/itex]" cancelled- that HAS to happen because [itex]\phi[/itex] is a function of y and z only. That's why not every function is a "gradient".)
Integrating [itex]\partial\ph/\partial y= z[/itex] gives us [itex]\phi(y,z)= yz+ \psi(z)[/itex]. Again, the "constant" of integration may be a function of z. That means that we now have [itex]f(x,y,z)= x^2y+ yz+ \psi(z)[/itex] and differentiating that with respect to z, [itex]\partial f/\partial z= y+ d\psi/dz= 1+ y[/itex] and the "y" term cancels leaving [itex]d\psi/dz= 1[/itex]. (That is an ordinary derivative because [itex]\psi[/itex] is a function of z only.) Integrating that, [itex]\psi(z)= z+ C[/itex] where now the "constant" of integration is now really a constant.
That gives [itex]f(x,y,z)= x^2y+ yz+ z+ C[/itex] and you can check that [itex]\nabla (x^2y+ yz+ z)= 2xy\vec{i}+ (x^2+ z)\vec{j}+ (y+1)\vec{k} for any constant C.[/itex]
i think i understand
so when we get zsin(xy)i +zsin(xy)j+z2 from integrating we have to check what we would get from differentiating this?
in this case the i term and j term don't need constants because they would differentiate right back to what they were integrated from? however for the k term we do because if we differentiate z2 we just get 2z not 2z+ sin(xy)
so we need to add on a term that will differentiate with respects to z to get sin(xy) namely zsin(xy)?
giving our full answer to be zsin(xy)i+zsin(xy)j+z2+zsin(xy)
Nooo … f is an ordinary function, not a vector …
when you integrate, you're aiming to get the same function f, each of the three times …
that's where the "constants" come in …
how can you combine zsin(xy) and z2 to get a single f that fits? :smile:
f=z2 +zsin(xy)?? is there a method to do this by or is it just inspection to find it?
That's right! :smile:
(and the method is what you just did …
didn't you like it? :wink:)
  • · Replies 17 ·
