Finding a Minimum Value for a Continuous Function on a Compact Set
  • Thread starter trap101
    Property
trap101
Suppose S[itex]\subset[/itex]ℝn is compact, f: S-->R is continous, and f(x)>0 for every x [itex]\in[/itex]S. Show that there is a number c>0 such that f(x) ≥ c for every x[itex]\in[/itex]S.
Attempt:
Since S is contained in Rn is compact, then S is closed and bounded.
By the extreme value thm there exists values a,b that are an absolute minimum and absolute maximum respectively. Let c = f(a). Therefore by EVT f(c) ≤ f(x) in R.Well I have the solution manual and their solution is way different to what I attempted. Is there anything right about this?
micromass said:
Also, this should be c≤f(x).
But isn't c [itex]\in[/itex] S. SO wouldn't the function map c to f(c)?
micromass said:
Your solution is correct. You might want to explain why c>0 however.
Is the fact c having to be positive because if c < 0 ==> f(a) < f(c) ?
You defined c=f(a). So c is an element of [itex]f(S)\subseteq \mathbb{R}[/itex]. Writing f(c) makes no sense.
Again, f(c) makes no sense.
