Finding Accel. of Particle: t1=2s t2=5s | Mean Accel.
  • Thread starter Thread starter JaySean
    Acceleration
The discussion revolves around finding the acceleration of a particle whose velocity varies quadratically with time. Participants are tasked with deriving equations for acceleration and distance, and calculating mean acceleration over a specified time interval.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore the relationship between velocity, acceleration, and time, questioning the use of formulas for constant acceleration. There are discussions about the need for calculus and the implications of quadratic velocity on the problem.
Some participants have made progress in identifying the formula for acceleration and have attempted to calculate mean acceleration. Others are still clarifying concepts and seeking guidance on how to approach the problem without relying on constant acceleration formulas.
Participants note the absence of initial conditions or additional information that might be necessary for solving the problem completely. There is also mention of homework constraints that prevent the use of standard formulas for constant acceleration.
JaySean
1. Not sure if it's the right forum but I'll try. The velocity of an particle varies quadratic with a formula based on time
a) Find the equation for acceleration and length as a function of time.
b) a = 3 m/s^3 (I think it's alpha)
Find the acceleration when t1=2s t2=5s and how big is the mean acceleration in the time intervall t2-t1.
2. See picture3. a) I think you can use the formula
saying u=0 (start velocity) and say a=(v-u)/t
And do the same for
where s= length. But is it that easy or are they looking for a different solution, as this is something I learned few years ago. Or do I have to antiderivate it, which would make it complicated because there is no known fact.
b) If a) is right could I then say solve v(t) which gives me t=3 alpha= 3 --> v(t)=27 m/s, and then get acceleration by the 2nd formula
v= 27 u=0 t=3, so acceleration is 9? Or am I on the wrong way?
That's a bit vague. Is any additional information given? Such as velocity at time 0.
hp?image=http%3A%2F%2Fupload.wikimedia.org%2Fmath%2Fa%2Fa%2F1%2Faa18f61b4e7c9b1afebb4a98a91f0456.png
Careful! Those formulas are for constant acceleration, which is not what you have here. (Note how the velocity is linear with time, not quadratic, in the formula.)
Hint: Calculus made be involved.
Doc Al said:
That's a bit vague. Is any additional information given? Such as velocity at time 0.Careful! Those formulas are for constant acceleration, which is not what you have here. (Note how the velocity is linear with time, not quadratic, in the formula.)
There is no additional information, but the formula (picture).
Do you have any hint to how I get started on solving b)?
Ah, I see it now. ##v(t) = 1/2 \alpha t^2##.
First solve part a).
Do I have to solve it as differintial equation? As I'm not allowed to use the formula for constant accerlation?
I know I can derivate v'(t) to get a(t)= at where a= alpha, but how do get to the length formula?
You'll have to use a bit of calculus. (How do distance, velocity, and acceleration relate to each other?)
That's correct. You cannot use the standard constant acceleration formulas here.
I know that the distance particle traveled is s(t)= antiderivative of v(t), but wouldn't I need additional information to find the constant?
Edit: Already found the formula for acceleration a(t)= qt where q is a constant
Not to find the distance traveled over a given time interval. That is the difference between two lengths
To express the position, you'd need additional info. But for the distance traveled, you can just set s(t=0) = 0.
Good. (That constant is given as ##\alpha##.)
Doc Al said:
To express the position, you'd need additional info. But for the distance traveled, you can just set s(t=0) = 0.Good. (That constant is given as ##\alpha##.)
(I didn't know how to write alpha so I just called it q)
So the formula for poisition as a function of time is S(t)=0 when t=0?
and for b) since a(t)=qt where q=3 m/s^3 for t1= 2s and t2=5s
a(2)=6 m/s^2 and a(5)=15 m/s^2
mean acceleration= 11/3 m/s^2
Yes, that will give you the position from the starting point (where t = 0, presumably).
Good.
How did you calculate that?
Sorry I meant 21/3 m/s^2 which is 7m/s^2
a(2)+a(5) =6+15=21
And t2-t1=5-2=3
a(2)+a(5) =6+15=21
And t2-t1=5-2=3
Careful! What's the definition of average acceleration?
Since I already know what alpha is and time is I might be able to use the general formula for acceleration knowing the velocity at beginning and end.
This gives me
vo=3*(2)^2=12
v1=3*(5)^2=75
acceleration= (75-12)/(5-2)=21
Good.
JaySean said:
This gives me
vo=3*(2)^2=12
v1=3*(5)^2=75
You left out the factor of 1/2.
Sorry this is stupid of me,
(37,5-6)/3 =10,5
v1-v0/delta(t)
I have another question not sure if anyone is able to answer:
Car with velocity 36 km/h colliding and stoping over a length of 1 meter (end velocity = 0). Find acceleration.
I have solved it the simple way using v^2 = u^2 + 2as and got the right answer.
Now my question is how do I set it up as an differential equation.
My attempt:
Since I know S(0)= 1 (saying start position is 1 and end is 0)
velocity start = 36km/h and end is 0
I also know that position is antiderivative of velocity
S(t)=∫36
S(t)= 36t+C
Attempt on finding constant c.
S(0)=36*0+C=1
C= 1
S(t)= 36t+1
JaySean said:
My attempt:
I would say that the start position is 0 and the end position is 1.
S(t)=∫36
You cannot assume that the velocity is constant. (After all, you are told that it is stopping.)
All you'll do, by setting up a differential equation, is derive those kinematic formulas. Nothing wrong with that, as long as you start with the correct assumptions. Assume that the acceleration is constant, then you can integrate to get the position as a function of time.
Do you mean derivating for example the formula
v=v0+at?
v=v0+at?
Yes. And, using a few tricks, all the others.
