Finding Acceleration of Blocks Connected by String
7 replies · 2K views
ƒ(x)
Problem: I've been assigned a problem that involves a block on a table that is attached by a string to a block hanging over the edge. They are of different masses, and I am given coefficients for both static and kinetic friction. The former is .50, and the latter is .30. I have to find the acceleration of the system if it is released from rest.
My problem: ok, so do I need to use the coefficient of kinetic friction at all? I do not think so...that's pretty much my question.
Can you show what equations you used? Kinetic friction should be used for surfaces moving relative to each other.
Hi ƒ(x)! :wink:
Do good ol' Newton's second law on each block separately, plus the fact that their accelerations must be the same (because the string length is constant).
What do you get? :smile:​
m1 (on table) = 10 kg
m2 = 4 kg
.5*Fn = Fs
.5*10*9.8 = 49 N = Fs
Fnet = Fx - Fs = 4*9.8 - 49 = -9.8 N
ma = -9.8
a = -9.8/m = -9.8/(4+10) = -.7 m/s/s
m2 = 4 kg
ohh! you didn't give the masses before :rolleyes:
no wonder you got a negative answer
.5*Fn = Fs
ma = -9.8
That doesn't make sense … how can the mass be accelerating upward?
What does it mean if the weight is less than the µsN ?
ƒ(x) said:
I'm guessing it means that the system isn't moving.
(why guessing? :rolleyes:)
That's right! …
if the system is released from rest, it will never move (even though if it was given a little nudge, the low µk would enable it to keep accelerating). :smile:
