Finding an Exact Solution for the Recurrence Formula f(n) = 2f(sqrt(n)) + n
  • Context: MHB
  • Thread starter Thread starter alyafey22
The forum discussion centers on solving the recurrence formula f(n) = 2f(√n) + n. Participants derive a bound for the function, concluding that f(n) = Θ(n log n) while expressing uncertainty about finding an exact solution. The use of the Master Theorem and substitutions such as n = 2^k and n = 2^{2^k} are explored to analyze the behavior of the function. Ultimately, the discussion highlights the complexity of obtaining a simple expression for the recurrence.
  • Understanding of recurrence relations and their solutions
  • Familiarity with the Master Theorem for analyzing algorithmic complexity
  • Knowledge of logarithmic functions and their properties
  • Experience with mathematical induction and bounding techniques
  • Study the Master Theorem in-depth, focusing on its conditions and applications
  • Explore advanced techniques for solving recurrence relations, such as generating functions
  • Investigate the properties of logarithmic growth in algorithm analysis
  • Learn about numerical methods for approximating solutions to complex recurrences
Mathematicians, computer scientists, and software engineers interested in algorithm analysis, particularly those dealing with complex recurrence relations and their implications in computational complexity.
alyafey22
MHB
Hello MHB
Solve the following recurrence formula
$$f(n) = 2f(\sqrt{n}) + n$$
I was able to find a bound for the function but no success in finding an exact solution. Any ideas ?
I don't think there is an easy expression for it. Using structural induction you can easily prove that the following holds for all $k \in \mathbb{N}$:
$$f(n) = 2^k f \left ( n^{2^{-k}} \right ) + \sum_{i = 0}^{k - 1} 2^i n^{2^{-i}} \tag{$\star$}$$
Now if we assume that $f(n) = c$ for all $n \leq 2$ (otherwise the recurrence does not converge) we can plug in $k = \lceil \log_2{\log_2{n}} \rceil$ to get:
$$f(n) = c 2^{\lceil \log_2{\log_2{n}} \rceil} + \sum_{i = 0}^{\lceil \log_2{\log_2{n}} \rceil - 1} 2^i n^{2^{-i}} = c' \log_2{n} + \sum_{i = 0}^{\lceil \log_2{\log_2{n}} \rceil - 1} 2^i n^{2^{-i}}$$
For $n > 2$ and with $c \leq c' < 2c$ depending on how close $\log_2 \log_2 n$ is to its ceiling. Unfortunately the sum does not seem to have a simple exact expression. However it is quite easy to see that the $2^i$ factor is upper-bounded by $\log_2{n}$, so that we have:
$$\sum_{i = 0}^{\lceil \log_2{\log_2{n}} \rceil - 1} 2^i n^{2^{-i}} \leq \log_2{n} \sum_{i = 0}^{\lceil \log_2{\log_2{n}} \rceil - 1} n^{2^{-i}}$$
Furthermore $n^{2^{-i}} \leq 1 + 2^{-i} n$ for all $i \geq 0$, so that:
$$\sum_{i = 0}^{\lceil \log_2{\log_2{n}} \rceil - 1} n^{2^{-i}} \leq \sum_{i = 0}^{\lceil \log_2{\log_2{n}} \rceil - 1} \left ( 1 + 2^{-i} n \right ) = \lceil \log_2{\log_2{n}} \rceil + n \sum_{i = 0}^{\lceil \log_2{\log_2{n}} \rceil - 1} 2^{-i} \leq \lceil \log_2{\log_2{n}} \rceil + 2n$$
Which gives us:
$$\sum_{i = 0}^{\lceil \log_2{\log_2{n}} \rceil - 1} 2^i n^{2^{-i}} \leq 2n \log_2 n + \log_2 n \lceil \log_2{\log_2{n}} \rceil$$
Or, putting everything together:
$$f(n) \leq \left ( 2n + c' \right ) \log_2 n + \log_2 n \lceil \log_2{\log_2{n}} \rceil \in O \left ( n \log{n} \right )$$
Of course, it does grow slower than that as the ratio of $f(n)$ to its approximation tends to zero but I don't know how to obtain a tighter bound. (did you find a better one?) In any case, I don't know how to find an exact solution either, and I doubt a simple expression for it exists :(
Assume that $n$ is a power of 2 then use the change of variable $n = 2^k $
$$f(2^k) = 2f(2^{k/2})+2^k $$
Now let $g(k) = f(2^k)$ so we have
$$g(k)= 2g\left( \frac{k}{2}\right)+2^k $$
Now if we use the Master theorem we get
$$g(k) = \Theta(2^k)$$
which implies that
$$f(n) = \Theta(n)$$
Very sleek! I wonder if an exact solution exists now.. :confused:
While all the other conditions of Case 3 of the Master Theorem hold, I don’t believe that the regularity condition,
$$ 2 \times 2^{k/2} \leq d \times 2^k, \ d < 1, \ k > N, $$
holds.
This holds for $ k \geq 2 \left (1-\log_{2} d \right ) $, but I don’t know…I’d like to have a numerical value for d that doesn’t depend on k. Maybe I’m wrong.
Anyway, I have a possible solution.
Starting from $ f(n) = 2 f(\sqrt n ) +n $, make the substitution $ n = 2^{2^k} $. The equation then becomes
$$ f \left ( 2^{2^k} \right ) = 2 f \left ( 2^{2^{k-1}} \right ) + 2^{2^k}. $$
Substituting $ g(k) = f \left ( 2^{2^k} \right ), $ the equation becomes
$$ g(k) = 2 g(k-1) +2^{2^k}. $$
Iterating, we see that
$$ g(k) = 4 g(k-2) + 3 \times 2^{2^k} = 8 g(k-3) + 7 \times 2^{2^k} = … $$
We see that
$$ g(k) = 2^c g(k-c) +\left ( 2^{c} -1 \right ) 2^{2^k} $$
for any c such that $ 1 \leq c \leq k. $
Iterating k times, we have that
$$ g(k) = 2^k g(0) +\left ( 2^{k} -1 \right ) 2^{2^k}. $$
Back substituting for $ g(k) $ and $ k $, we get
$$ f(n) = f(2) \log_{2} n +\left ( \log_{2} n -1 \right ) n. $$
Rearranging,
$$ f(n) = (f(2) +n ) \log_{2} n -n, n = 2^{2^k}. $$
holds.
You need to find only one value for $0<d<1$ such that the regularity condition holds. Here we can choose $d = 1/2$
$$ 2^{k/2} \leq 2^{k-2}, \ k > 4 $$
I don't see how you obtained the coefficients of $2^{2^k}$ ?
Oh, I see.
Since
$$ g(k) = 2 g(k-1) +2^{2^k}, $$
$$ g(k-1) = 2 g(k-2) + 2^{2^k}. $$
Substituting into the previous relation, we have that
$$ g(k) = 2 \left ( 2 g(k-2) +2^{2^k} \right ) +2^{2^k} = 4 g(k-2) + 2 \times 2^{2^k} + 2^{2^k} = 4 g(k-2) +3 \times 2^{2^k}. $$
Iterating c times, the coefficients of $ g(k-c) $ are $ 2^c $, and the coefficients of $ 2^{2^k} $ are $ 2^{c} - 1 $.
jacobi said:
Oh, I see.Since
$$ g(k-1) = 2 g(k-2) + \color{red}2^{2^k} $$
Ah, I think you missed to rewrite $2^{2^{k-1}}$
(Swearing)(Swearing)(Swearing)
I can't believe I made such a stupid mistake. Forgetting to substitute $k-1$ for $k$...:mad:
Anyway, if you iterate CORRECTLY k times, you get
$$ g(k) = 2^k g(0) + \sum_{j=0}^{k} 2^j 2^{2^{k-j}}.$$
Then,
$$ f(n) = f(2) \log_{2} n + \sum_{j=0}^{\log_{2} \log_{2} n } 2^j n^{2^{-j}}, $$
which I can't find an exact expression for (yet).
  • · Replies 29 ·
  • · Replies 22 ·
  • · Replies 19 ·
