Finding angle B in a triangle given angle C is 55 degrees
  • Thread starter hvidales
    Angle
10 replies · 3K views · last reply
hvidales
Find angle B
Triangle makes 180 degrees
I brought the red vector(Red Vector was given) down more to make a right triangle and got 55 degrees for C. I do not know where to go from there though to get angle B. Angle B is also 35 degrees but I don't know how they got that.
[url=http://postimage.org/][PLAIN]http://s17.postimage.org/6onxtnlbz/Untitled.png[/url][/PLAIN]
The line labeled "x" is parallel to the slope incline. The lines labeled "x" and "y" are presumably perpendicular. You should be able to take it from there.
hvidales said:
Find angle B
What angle does the x-axis make with the y-axis ?
90 degrees
hvidales said:
90 degrees
Then, what is the sum of (angle B) + (angle C) ?
would it be 90 too? I also had another question, the angle where B is at, is that whole piece a another right triangle?
See attachment. I labeled another angle, D, in blue. Given that the line labeled "x" and the slope incline are parallel, what can you say about angles C and D?
  • Hand-drawn diagram of a block on an incline at 35 degrees to a horizontal dashed line, with axes x and y, a red downward arrow, and angles labelled B, C and D.
Are they equal to each other?
eumyang said:
Yes.
oh so these are two parallel lines cut by a transveral right?
Again, yes.
