Finding Angle of Sphere Falling From Table Edge
139 replies · 15K views
Satvik Pandey said:
By finding torque about the contact point
## mgsin\theta r=\frac { 7 }{ 10 } m{ r }^{ 2 }\alpha ##
Is this equation correct? ## \frac { 7 }{ 10 } m{ r }^{ 2 } ## is half the moment of inertia about the contact point.
I think I need the value to ##r##(radius of that sphere) to find the angle at which sphere looses contact with the cliff. right?
Not really. Observe that you can change variables in the original equations as follows: $$ p = {I \over 2 mr^2} \\ z = {v^2 \over r } \\ N = mg n , $$ which then gives $$ g(1 - \cos \theta_0) = pz_0 \\ g \sin \theta_0 = pz'_0 \\ g(\cos \theta - n) = z \\ 2g( \sin \theta - \mu n) = z', $$ where the prime denotes differentiation with respect to ##\theta##.
##z## and ##z'## can be eliminated from these equations, yielding a differential equation and initial conditions for ##n##, without any dependence on ##r## .
No. Finish your solution. No need to start a new one . Find C from the angle and speed of the CoM at the end of the first stage when the slipping started. Then you know how v2/r changes with the angle during the second stage. You had an equation where both v2/r and N were involved. Eliminate v2/r. The ball looses contact with the cliff if N=0.
Thanks!:)
I have made an equation for the motion of the CoM at the moment at which it looses contact with the cliff in #post86.:rolleyes:
Sorry, I am little busy now a days because my tests are going to start from 24th Nov.:H
I will come back to this after 10 days.:p
I am replying exactly after 10 days.:D
So 41.82 deg.=0.73 radians
Now from equation
##g(1-cos\theta )=\frac { 7 }{ 10 } \frac { { v }^{ 2 } }{ r } ##
I got value of ##v^{2}## at angle 41.82 is 3.56##r##.
Putting that in solution of that differential equation I got
##C=14.6859r##. Is it right?
So
##v^{2}=-rg\left\{ \frac { 3sin\theta +cos\theta }{ 2 } \right\} +{ 14.69e }^{ \theta }##
and I also have
##\frac { m{ v }^{ 2 } }{ r } =mgcos\theta ##
I need to find ##\theta## from these equations. So I need to eliminate ##r##
Do you want me to eliminate ##r## using these--
##mgcos\theta -N=m\frac { { v }^{ 2 } }{ r } ##
and ##\\ mgsin\theta -\mu N=ma##
But these equations are for the moment at which the ball's CoM is doing circular motion about the contact point. So even if the ball is slipping we can use these equations. right?
Should I find another equations from these equations between ##r##,##v## and ##\theta##?
Now from equation
Be more specific. What was the equation you got v2? (I remember that it was the equation for the no-slip case at the end when slipping started, but other might not know.) What do you mean with "Putting that in solution of that differential equation " - which differential equation do you mean?
Satvik Pandey said:
So
That equation should be ##v^{2}=-rg\left\{ \frac { 3sin\theta +cos\theta }{ 2 } \right\} +14.69 r e^{ \theta }##
Satvik Pandey said:
and I also have
From where do you have that equation? What does it mean? (Again, I know, but other people reading your solution might be confused, what it means. )
You had two equations at the start of the problem concerning the slipping stage of the motion. You have solved them. There are no more equations and you do not need more.
You see that r cancels if you correct your mistake concerning C. And you need to find theta, where the ball detaches - what does it mean for N?
I got this equation by conservation of energy. I have mentioned it in #post . And I am talking about differential equation which is mentioned in #post 133.
I have mentioned that equation is #post 86.
The moment at which ball looses contact with the cliff the normal force acting on it will be 0. So at that moment the component of weight(mg) is responsible for providing the centripetal force.
So the component of mg = centripetal force
I tried this
Now
##\frac { { v }^{ 2 } }{ r } =-g(\frac { 3sin\theta +cos\theta }{ 2 } )+14.69{ { e }^{ \theta } }^{ \\ }##
and ##\frac { { v }^{ 2 } }{ r } =gcos\theta ##
So
or ##gcos\theta +\frac { gcos\theta }{ 2 } +\frac { 3gsin\theta }{ 2 } =14.69{ e }^{ \theta }##
or ##\frac { 3g }{ 2 } (sin\theta +cos\theta )=14.69{ e }^{ \theta }\\ ##
or ##{ e }^{ \theta }=(sin\theta +cos\theta )##
Taking log on both side I got
##\theta =\ln { (sin\theta +cos\theta ) } ##
I don't know much about logarithms. How should I find ##\theta##?
When writing a report, a paper or even a test, you should explain your steps. That equation you used described the motion of the ball when it did not slip. The angle you reported was the end of that stage and the initial angle of the next stage, the ball slipping. You should have written something like that.
That is better...
Satvik Pandey said:
I tried this
Now
So
You lost 3g/2 :)
You must have learned about logarithm.
You can not solve the equation in closed form. Apply some numerical method.
But check C first. I do not think it is correct.
ehild said:
But you have to know it for your life... It is very basic.I do not think you solved the correct equation. Check.
I hate long calculations.:H##\frac { 7 }{ 10r } { v }^{ 2 }=g(1-cos\theta )##
I got this from equation energy conservation-
Putting g=9.8 ##\theta=41.82## I got ##v^{2}=3.56r##
Now the the solution diffrential equation was
##x=-rg\left\{ \frac { 3sin\theta +cos\theta }{ 2 } \right\} +{ Ce }^{ \theta }.##
where ##x=v^{2}##
So at ##\theta=41.82## ##v^{2} is 3.56r##
So putting values I got
##3.56r=-rg\left\{ \frac { 3sin(41.82)+cos(41.82) }{ 2 } \right\} +{ 2.72 }^{ 0.73 }C##
According to wolfram alpha ##C=4.67726##.
Please see this http://www.wolframalpha.com/input/?i=Find C if 3.56r=-9.8r(3sin(41.82)-cos(41.82))/2 + 2.72^(0.73) C&a=*C.r-_*Variable.dflt-&a=*C.C-_*Variable.dflt-&a=TrigRD_D
Where am I going wrong?
I have long lost track of the unnecessarily over-complicated approach that Satvik has been ill-advised to undertake. Here is a simpler method. I continue from my post #124. The equations there can be simplified further by noticing that ##p = {7 \over 10} ## and ## \mu = 0.5 ##. To simplify typing, in what follows I will use the shorthands ## c = \cos \theta, \ c_0 = \cos \theta_0, \ s = \sin \theta , \ s_0 = \sin \theta_0 ##, and I also let ## z =g u ## so the simplified equations are $$ {10 \over 7}(1 - c_0) = u_0 \\ {10 \over 7}s_0 = u_0' \\ c - n = u \\ 2s - n = u'. $$ The second pair of equations are valid for all angles, including ##\theta_0##, so I obtain $$ c_0 - n_0 = u_0 \\ 2s_0 - n_0 = u_0'.$$ Using the first and third pairs, I obtain $$ 17 c_0 - 4 s_0 = 10 \\ n_0 = {4 \over 7} s_0 .$$ The first of these can be converted to a quadratic equation with respect to ##s_0##, and solved, yielding $$ s_0 = 0.667 \\ c_0 = 0.745 \\ \theta_0 = 0.730 \\ n_0 = 0.381. $$
Turning to the second pair, it trivially yields $$ n' - n = - 3 s, $$ whose solution, according to #120, is $$ n(\theta) = e^\theta \left[n_0 - 3 \int \limits_{\theta_0}^\theta e^{-t} \sin t dt \right] .$$ We are looking for the angle when ##n = 0##, so all that remains to be done is to solve $$ 0.381 = n_0 = 3 \int \limits_{\theta_0}^\theta e^{-t} \sin t dt = 1.021 - {3 \over 2} e^{-\theta} \left(\cos \theta + \sin \theta\right).$$
where ##x=v^{2}##
Almost correct :). v2=3.566 r.
Do not substitute e with 2.72. It reduces accuracy.
Satvik Pandey said:
You typed in 3sin(41.82)-cos(41.82) instead of 3sin(41.82)+cos(41.82). Do not mix radians and degrees in the same equation. Use 0.73 for theta everywhere. And you get a number times r for C. :
##3.566 r=-rg\left\{ \frac { 3sin\theta +cos\theta }{ 2 } \right\} +{ C re }^{ \theta }.##
Here is the solution with Wolframalpha.
http://www.wolframalpha.com/input/?i=Find C if 3.566=-9.8(3sin(0.73)+cos(0.73))/2 + e^(0.73) C
So the value of ##C=8.20r##
So ## { v }^{ 2 }=-rg\left( \frac { (3sin\theta +cos\theta ) }{ 2 } \right) +8.20r{ e }^{ \theta }##
or ##\frac { { v }^{ 2 } }{ r } =-g\left( \frac { (3sin\theta +cos\theta ) }{ 2 } \right) +8.20{ e }^{ \theta }##
but ##\frac { { v }^{ 2 } }{ r } =gcos\theta ## (got this relation from the equation for the moment at which ball looses contact with the cliff)
or ##gcos\theta =-g\left( \frac { (3sin\theta +cos\theta ) }{ 2 } \right) +8.20{ e }^{ \theta }##
Is it fine now?
According to wolframalpha the value of ##\theta=0.92rad=52.71degrees##
here is solution http://www.wolframalpha.com/input/?i=solve for x if 9.8cos(x)=-9.8((3sin(x)+cos(x))/2)+8.2(2.72)^x.
ehild said:
Correct at last ! (sigh... )
Thanks! At last got correct answer.:)
I did lots of mistakes in calculation in this thread that's why this thread became too long.:rolleyes:
