Finding area from a geometric figure
  • Topic:
  • Thread starter Thread starter susanto3311
    Area
16 replies · 5K views
susanto3311
hi all...
please, see my picture, the area is...
a) 217 cm2
b) 434 cm2
c) 154 cm2
d) 294 cm2
thanks in advance...
susanto
Mathematics news on Phys.org
susanto3311 said:
hi all...
a) 217 cm2
b) 434 cm2
c) 154 cm2
d) 294 cm2
susanto
Hey susanto3311! ;)
What would be the radius of the circle?
I like Serena said:
Hey susanto3311! ;)
the radius is 28 - (2x7) = 14 cm..
it's true?
it's true?
Almost. That's the diameter. The radius is half of that.
What would be the height? (Wondering)
hi Serena, i don't know?could you show me...
The cross stripes seem to indicate a height of 2x7=14 cm.
Now which parts does the area consist of and what are their areas?
I think you should be able to find those by now...
i still confuse...how do make more easy?
Please, could you give some indication of where you are stuck?
Or what you are thinking?
hello Serena,
here my problem..
susanto3311 said:
hello Serena,
here my problem..
Good! (Smile)
You have already found that the diameter at the bottom is 14 cm.
So the distance at the top should also be 14 cm.
As for the diagonals of the triangles, you don't need them.
But if you want, you can calculate them using the Pythagorean Theorem $a^2+b^2=c^2$. Or more to the point: $c = \sqrt{a^2+b^2}$.
On the left you have a right triangle with base 7 and height 14.
Do you know how to calculate its area? (Wondering)
I like Serena said:
Good! (Smile)
hi Serena,
i think like this..
it's all true answer?
susanto3311 said:
hi Serena,
i think like this..
You have the right parts with the right areas. Good!
However, they should not simply be summed.
- You should have 2 triangles of 7x14 instead of 1.
- There is only half of a circle, so its area should be divided by 2.
- The half circle is something that has been removed from the object. So instead of adding it, it should be subtracted.
(Thinking)
Another way to approach this would be to find the area $A_T$ of the trapezoid (all areas in $\text{cm}^2$):
$$A_T=\frac{h}{2}(B+b)$$
Now find the area $A_S$ of the semi-circle:
$$A_S=\frac{\pi}{8}d^2$$
And so the area $A$ of the given figure is:
$$A=A_T-A_S=\frac{h}{2}(B+b)-\frac{\pi}{8}d^2$$
You know all of the following:
$h$ = height of trapezoid
$B$ = "big" base of trapezoid
$b$ = "little" base of trapezoid
$d$ = diameter of semi-circle
So now just plug the numbers in, and round to the nearest integer. What do you find?
maybe, i have try..
susanto3311 said:
maybe, i have try..
Yep! That's it! (Happy)
One improvement: for area 1 you should have {(7x14)/2}x2 = 49x2 = 98, but that's what you used anyway.
hi..
why different result with 2 method :
like this ..
where is something wrong?
susanto3311 said:
hi..
like this ..
The symbols are mixed up.
The diameter d should be 14 cm.
The "big" base B should be 28 cm.
And the "little" base b should be 14 cm.
