Finding da/dt using implicit differentiation with 1/a = 1/b + 1/c
10 replies · 2K views · last reply
jisbon
Let ##\frac{1}{a}=\frac{1}{b}+\frac{1}{c}##
If ##\frac{db}{dt}=0.2## ,## \frac{dc}{dt}=0.3## , Find ##\frac{da}{dt}## when a=80 , b=100
Homework Statement: Let ##\frac{1}{a}=\frac{1}{b}+\frac{1}{c}##
Homework Equations: -
Since we are supposed to find ##\frac{da}{dt}##, I can deduce that:
## \frac{da}{dt} =\frac{da}{dc}\cdot\frac{dc}{dt} = (\frac{db}{dc}\cdot\frac{da}{db})\cdot\frac{dc}{dt} =((\frac{db}{dt}\cdot\frac{dt}{dc})\cdot\frac{da}{db})\cdot\frac{dc}{dt} = ((\frac{0.2}{0.3}\cdot\frac{da}{db})\cdot0.3## = Answer?
To find ##\frac{da}{db}##, I need to differentiate implicitly, which gives me ##\frac{da}{db}##=1 ? (Not sure if it's correct), hence the answer is 1*0.2/0.3*0.3?
Thanks
No, that's not correct. Differentiate both sides of the original equation with respect to t, not b. Assume that each of a, b, c is a function of t. You will get an equation with the three derivatives wrt t in it, and the three amounts a, b, c. Making the above numeric substitutions you will get an equation that relates ##\frac{da}{dt}## to c. You can rearrange that to express ##\frac{da}{dt}## in terms of c, which is what I presume they want you to do.
Delta2 said:
in addition to what @andrewkirk says, you can also find c when a=80,b=100 by using the original equation.
Will it be something like: ##\frac{-1}{a^2}\frac{da}{dt}=\frac{-1}{b^2}\frac{db}{dt}+\frac{-1}{c^2}\frac{dc}{dt}##?
Oh ok. Then I guess I could solve the question easily now. Thanks for the clarification :smile:
It is often seen as an application of the chain rule as others said. First equation sets up a as a function of b,c and it is assumed both b,c are functions of t. Then we apply the total derivative which uses the chain rule ,i.e, we have a=a(b(t),c(t)) and we go from there to define da/dt.
Or more simply, without using the total derivative...
Since a is a function of b and c, with b and c being functions of t, then a is also a function of t.
Just differentiate all with respect to t using the chain rule, exactly as @jisbon shows in post #4.
I don't know of any setup for chain rule using two variables that does not use the total derivative. I have seen, of course, for one variable but not for two or more. But I guess it comes down to the same in the end.
You don't need to treat a as a function of two variables; i.e., a = f(b, c).
All you need is to treat a, b, and c as implicit functions of t, and then differentiate implicitly, as hinted at in the title of this thread. IOW, you can interpret the original equation to mean ##\frac 1 {a(t)} = \frac 1 {b(t)} + \frac 1 {c(t)}##.
BTW, this is standard fare in first quarter/first semester calculus, usually presented before any discussion of the total derivative.
Well, now the OP knows two techniques and can choose which one to apply. I get to decide since i have 4444 messages, using 44 twice--- not just once;).
