Finding Davina's height with algebraic equations instead of trial and error
  • Thread starter Thread starter Natasha1
    Difference
12 replies · 3K views
Natasha1
Pritesh is taller than Davina who is taller than Alicia. The difference in height between Pritesh and Davina is the same as the difference in height between Davina and Alicia. The total of their heights is 300 cm. How tall is Davina?
Now trial and error gives me Alicia = 50cm, Davina = 100cm and Pritesh = 150cm as the difference between them is 50cm
How could I do this problem using only algebra, rather than what I did with trial and error?
Maybe P+D+A = 300
P-D = D-A
Are those two equations enough to get the solution? :smile:
P = 2D - A
So substituting gives
2D - A + D + A = 300
3D = 300
D = 100
How do I get P and A?
Hi, let's write these info:
P+A+D= 300
D-P=A-D
You need D
Look at the second equation, you can write it as: 2D= P+A , that's amazing
Look at the first : (P+A)+D= 300
Can you see it?
Natasha1 said:
P = 2D - A
3D = 300
D = 100
You can't, you need another equation, but you only need D
Cozma Alex said:
2D= P+A
Cozma Alex said:
(P+A)+D= 300
Natasha1 said:
D-100=A-100
Just re-check your algebra... :smile:
P-D = D-A
so
P - 100 = 100 - A
P = 200 - A
A = 200 - P
Is this correct?
Natasha1 said:
P = 2D - A
3D = 300
D = 100
So Davina is 100 cm tall, that is correct.
You don't have enough information to answer that question. That's why you are only asked how tall Davina is.
Can you remember a technique that allows you to deal with more than one unknown quantity, and can you recognize the quantity you do not need to answer this question?
Hint: look at your algebra, it'll be easier to think about this algebraically than from just reading the problem text (which is what you're asking for, correct?).
Let P be the Pritesh's height, in cm, D be Davina's height in cm., and A be Alicia's height in cm.
So P- D= D- A.
And A+ D+ P= 300. That give two equations, P- D= D- A and A+ D+ P= 300 to solve for three unknowns. That is not enough information. We need one more equation. We Could write P- D- A as 2D= P+ A and replace "P+ A" in the second equation by 2P to get 2D+ D= 3D= 300 to get D= 100. But putting D= 100 in either of the two equations gives P- 100= 100- A so that A+ P= 200.
2. Homework Equations
Now trial and error gives me Alicia = 50cm, Davina = 100cm and Pritesh = 150cm as the difference between them is 50cm.
Yes, that is one solution. But taking, say, A= 40, P= 200- 40= 160 also satisfies A+ P= 200 so also satisfies "P- D= 160- 100= 60" and "D- A= 100- 40= 60". Or taking A= 25, P= 200- 25= 175, which also satisfies A+ P= 200 as well as "P- D= 175- 100= 75" and "D- A= 100- 25= 75".
3. The Attempt at a Solution
