Finding distance from point to plane with Lagrange multipliers
5 replies · 3K views · last reply
EEWannabe
URGENT - Lagrange Multipliers
:confused:
Using the method of lagrange multipliers prove the formula for the distance from a point (a,b,c) to a plane Ax + By + Cz = D
Using the equation of the form;
H(x,y,z,L) = (x-a)^2 + (y -b)^2 +(z-c)^2 + L(Ax + By + Cz - D)
Therefore by differentiating, a relationship between x, y and z can be found with lamba, nameley;
x = (-LA/2) + a
y = (-LB/2) + b
z = (-LC/2) + c
By inserting these back into the equation for a plane I get to this stage for L;
[tex]L = \frac{2(Aa + Bb + Cc - D)}{A^2 + B^2 + C^2}[/tex]
Thus, putting this back into the Lagrange equation the value for D^2 I get is (D^2 =(x-a)^2 + (y -b)^2 +(z-c)^2);
[tex]D^2 to plane = \frac {2(Aa + Bb + Cc - D)(Ax + By + Cz - D)}{A^2 + B^2 + C^2}[/tex]
However this is at ends with;
[tex]D to plane = \frac{(Aa + Bb + Cc - D)}{(A^2 + B^2 + C^2)^_\frac{1/2}}[/tex]
I can't see what's gone wrong :confused:, I know i can't expect anyone to do it straight away or anything but I have a big exam tomorrow and there'll definatley be a question on something like this, any hints would be fantastic!
Thanks again
Do not use the same symbol, D, for both the parameter in the linear equation of the plane and for the distance to the plane. This _might_ be the source of the trouble.
PS. I get your expressions for x, y and z, and I get your first value of L. After that, we differ.
RGV
RGV
But I only added that D as the distance to the plane right at the end :(, and by that D i simply mean
(D^2 =(x-a)^2 + (y -b)^2 +(z-c)^2) , have edited it now though..
Could you give me any hints as to why yours is different? :( To get so the D from the value of L, i simply put L back into the lagrange equation, the first one..
It's better to eliminate lambda (L) from the equations you get by differentiating.
x- a+ LA= 0, y- b+ LB= 0, z- c+ LC= 0 can be rewritten as x- a= -LA, y- b= -LB, z- c= -LC. Dividing the first equation by the second, (x- a)/(y- b)= A/B so B(x- a)= A(y- b). Dividing the first equation by the third, (x- a)/(z- c)= A/C so C(x- a)= A(z- c).
y= b+ (B/A)(x- a), z= c+ (C/A)(x- a).
Put those into Ax+ By+ Cz= D and solve for x.
Thank you so much sir
I mis-read what you wrote because use used the same symbol D for two different things and L for two different things---a bad practice! I _do_ get your final result for the distance, although you should remember that you got it by taking a square root of something of the form N^2/M^2 (where M > 0), so the distance, d, is d = +- N/M = |N|/M. (Your N = a*A + b*B + c*C - D could be < 0.)
RGV
