FInding distance from top of diving bell to lake surface
34 replies · 5K views
Also I was focusing too much on the inside of the tube and missed that that interface sat at a certain height in the lake overall.
I solved it before with no idea about this. I guessed and missed all this thanks for the help!
One last thing. Is it corret to say that the pressures at that interface are the same?
Yes. Action and reaction, equal and opposite.
Ok. So the air portion in the tube has a uniform pressure correct? While the fluid portion varies with depth?
This is why there is a partition. The Gas exerts the same pressure on the liquid as it does on the gas.
Yes. Strictly speaking, the pressure also varies with depth in the air, but the density of air is so low that you can ignore that over a height of a few metres.
RIght because gravity does affect it but so much that it's negligible so. You can use pascual on gases so to speak but the affect or calulation would be super small..
I guess another way to look at it is that the gas has to be equal because it stops the water from moving(equal and opposite).
